Old 02-05-2022, 12:58 PM
Gach's Avatar
Gach Gach is offline
But a with cam change he said it’ll make 950 hp.
Old 02-05-2022, 03:45 PM
pastry_chef's Avatar
Originally Posted by Gach View Post
Heads are BES Victor heads ( E-Heads ) they flow 480 cfm.
Very curious on valve sizes they will use.
I'd guess HP peak around 7000 RPM with that cam.
Agree with BES comment about .800 intake valve lift min. My stuff has .794 and .808 for 7000 RPM target.
Old 02-05-2022, 03:58 PM
Gach's Avatar
Got a bunch more questions to ask him, your making me think. they are super busy. So think best to e-mail let him take time answer me back. Yeah I’m likely stay with cam I have and go with 1.8 shaft rocker. 830 lift.
Old 02-06-2022, 11:11 AM
slowbird's Avatar
slowbird slowbird is offline
Your current combo makes 850hp correct? And you're thinking this combo will make 890-900?
Those heads alone cost $11k seems like an a lot of money just for 40-50hp??
Old 02-06-2022, 02:18 PM
Gach's Avatar
It’ll make 100 more hp, your off a little on price their not $11 their $8000.00. Have 3 guys who want to buy old top end. Heads, intake, rocker shaft set up. So its more like a 3-$4000.00 investment. It’s jr decision not mine. He’s a high roller. LOL Hey if it keeps him from going BBC go for it.
Old 02-06-2022, 02:25 PM
slowbird's Avatar
I was quoted $9500 ready to bolt on without rockers, so add $1500 for rockers. Wonder why there is a $1500 difference between ur quote and mine?
Old 02-06-2022, 02:32 PM
Gach's Avatar
Dude I have the quote in writing. Still 9500.00 not $1100.
Old 02-06-2022, 02:41 PM
Gach's Avatar
Maybe you’re not a good negotiator. LOL is your quote with titanium valves
Old 02-06-2022, 04:54 PM
slowbird's Avatar
9500 plus 1500 for rockers is 11000
Old 02-06-2022, 05:27 PM
Gach's Avatar
Did you miss the question? Is your quote with titanium valves, that’s what another 1500.00 over stainless steel valve
Old 02-06-2022, 06:02 PM
Gach's Avatar
I’ll help you out, so if your quote was 9500.00 with titanium valves, which is $1500.00 more then stainless steel valves and mine with stainless steel valves. Doesn’t the math work out to my $8000. Quote. Glad to help you out, I know it can be a little confusing.
Old 02-06-2022, 09:27 PM
Stan Weiss's Avatar
Lou,
I take it these heads are going on an existing short block. Do your pistons have the valve pocket depth and radial clearance for the valve sizes in these heads? How about with increased rocker arm ratio?
Stan
PS Does anyone know if the valve center lines have been moved?
Pontiac Pump Gas List
Old 02-06-2022, 09:42 PM
Gach's Avatar
Shouldn’t be a problem, I’ve had set of heads with 1.8 rocker shaft and there was plenty of piston to valve clearance… cam was 856 lift. They were 65 cc chambers. Pistons have 16 cc dish and valve pockets are clearance for 2.300 valve. Of course I’ll double check everything.
Old 02-06-2022, 09:45 PM
Gach's Avatar
Just just made me think, have ask what valve angle is, heads on their now 14 degree angle.
Old 02-06-2022, 10:40 PM
slowbird's Avatar
Most like they're 11.5° and valves are in a different location and different valve spacing than regular e-heads.
Good luck with your build
Old 02-07-2022, 01:10 AM
Stan Weiss's Avatar
Lou,
Doesn't BES's web site say 2.35" intake and 1.68" exhaust?
Stan
Old 02-07-2022, 01:41 AM
Gach's Avatar
Tell you truth I never looked, but I will now.
Old 02-07-2022, 01:46 AM
Gach's Avatar
Don’t doubt it, I’ll fine out for sure.
Old 02-07-2022, 02:04 AM
Gach's Avatar
Originally Posted by Stan Weiss View Post
Lou,
Stan
Yep 2.35 intake valve.
Old 02-07-2022, 10:42 AM
Steve C. Steve C. is online now
The 2.350 valves are stated for their "Small Port Program" with 452 cfm @ 1.000" :
BES / Edelbrock Pontiac Victor Heads - Small Port Program
https://www.besracing.com/racing-eng...elbrock-victor
Same valves for the 480 cfm stated here in post #2 ?
"The intake valves have also been moved away from the cylinder wall allowing for improved burn characteristics when used with larger than stock diameter valves."
Also note different CFM numbers and valve angles here.
https://butlerperformance.com/c-1234...nderheads.html
Old information here:
