I mount mine on a bracket I made that attaches to the dash just to the right of the steering wheel. I use my pointer finger to push it. I had it on the steering wheel for a long time and it’s a pain turning the wheel with the cord wrapping around the steering column. You also have to be really careful not to bump the button after you launch or while driving in the pits. I had to install a lockout timer because I bumped it a couple times right after I launched. That’s not a good thing to do.
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0 2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion and 2015 IHRA Div 5 Mod champion |
Mine is bolted to the back of the shifter where I can't accidentally activate it. I also have an arming switch that I leave off when street driving to assist in no accidental activation.
However usually at the first race of the year I forget to arm it and once staged I try to get up on the brake and away we go, lol.
Whitmore 462, 670 heads 10.55@125 Same with 310 E D-ports 10.12@131 498 w/single 88 8.53@158 |
Probird - could I get some more info on your lockout timer?
Curious George - lol on not arming it, mine isnt street driven but I would probably forget too if it was |
The Following User Says Thank You to dv657172 For This Useful Post: | ||
OGR
3 Generations of "Beach Boys Racing" ! Everybody knows somthin. Nobody knows everything ! 1st time on a dragstrip, 1964. Flagstart ! "Thanks for the entertainment." "Real Indians Don't Wear Bowties" |
The Following User Says Thank You to Old Goat Racer For This Useful Post: | ||
Well I moved the transbrake button to the RHS of the steering wheel...I ended up moving it back to the dash before my first run as those who said the cord gets in the way were correct, at least for me. May investigate moving it to the shifter next or just leave as is which is ok. I just thought closer would be better.
Thanks again for all your thoughts |
"Artificial intelligence is no match for natural stupidity". 1966 GTO Post Coupe, 467ci. N/A Pump gas, best 1/4 11.6 118mph 1966 GTO Post Coupe, "The Bright Idea" 535ci. N/A Pump gas, best 1/4 9.56 139mph |
Looks like a nice setup! Thanks for the pic
DV |
T-Brake Top right.
2023 Best ET Slip 60’ 1.224 330 3.186 1/8 4.784 MPH 152.07 1000 6.175 ET 7.347 MPH 189.92 Weight 3650 YouTube Channel --> https://www.youtube.com/channel/UC21...rWwgFdfTRqShGQ FaceBook Group --> https://www.facebook.com/groups/220092308823847/ |
Thks RAIV-Z for the pic. I initially moved mine to a similar spot but with a pretty good size column tach in basically a 1 pm position and a stock column the cord gets in the way of trying to turn the car getting it on and off the trailer and moving it around in the pits even with a stretch cord.
I put mine on the dash.
A new best of 9.135 @ 145.41 71 Lemans Sport. 72 Lemans Sport. |
Thats where mine was initially, in the radio on/off hole. I thought it would be better closer to me but the steering wheel wasnt too productive on my initial attempt so currently its back on the dash too. I do like Bob 66 setup which I may investigate further
I did not like it on the shifter because I had my hand on it and Immediately I would shift into 2nd gear.
I had one button on the shift handle and a single pole double throw switch on the console. Toggle in the back position was line lock and I could upshift easily through the gears with my thumb on the gearshift button, and then toss the switch forward for the trans brake. Easy to see the switch position too.
I agree with the above that only real trans killing procedure was catching traction in second gear. I start in first and quickly go second and third and come out in high gear. Cost me a sprag early on years ago ending the burnout in second. The friend that bought my car forgets to hit third and already on his third sprag. To each his own and the friend ripped out all the upholstery and the console and went with one racing seat and a gate shifter with separate buttons on the steering wheel for line lock and trans brake.
Thats a creative way to use just one switch. I would probably forget to move the toggle. Thanks for the color on your burnout experience...so is he still your friend? lol
