Putting a spring on the pedal to pull it back up too. Auto part store springs look kinda dinky. Anyone know where to get a decent spring
PY has the correct springs. If your talking about universal springs Dorman has them. I found an assortment of springs on a card. In the Help section, which is Dorman, at Carquest. IIRC.
I walked all the way out to the garage just for you. I hope you appreciate it. Dorman 29004 available at your local parts store. Now, Geter done! Murf Sent from my iPhone using Tapatalk Pro |
I looked on Ames and all they had was the fork to ? Spring. I ordered a set of those springs today. I will try them on the pedal. Thanks
I thought you were going to try the 66 staple setup? Sent from my iPhone using Tapatalk Pro |
I meant to say 66 spring set up. Sent from my iPhone using Tapatalk Pro |
1965 Pontiac GTO 455/469 w/ #48 Heads, '65 Tri-Power 9.25:1 CR Stump Puller Cam Muncie M22W 1st-2.56 2nd-1.75 3rd-1.37 4th-1.00 3.55 Rear Differential Front: 225/60R15 Height: 25.6" Rear: 275/60R15 Height: 28" |
Oh I got those springs I just meant a spring from the pedal to the dash to pull it all the way up. I found one
Will try those 66-67 springs when the pushrod gets here this saturday
