Old 08-31-2003, 10:16 AM
dave bolduc dave bolduc is offline
my 69 bird runs way hot too..avg 210 - 250. I was turned on to a great solution - water wetter. this is used for parade cars where the heat and lack of air flow kill. I drained and flushed my radiator and added this little bottle of heaven sent mystery solution to regular water...thats right water. My operasting temp went down to 185 and stayed there. no other mods were done! I ran on this all last summer in NJ and was just amazed. The drawback obviously is cold weather, you will pop a freezeout plug if u leave it in, But from may till oct I am fine. The bottle cost under $10.
I am running a 350 4bbl bored 30 over with a 4 sp manual
Old 09-03-2003, 01:11 PM
PLAY400's Avatar
PLAY400 PLAY400 is offline
The funny looking bent clip is to be soldered on the lower passenger side of the rad above the lower rad hose where the tank meets the core and the shroud clips into it. there is a divot in the shoud where it connects. If this isn't fastened right the shroud will move and hit the fan. The other clip if I'm not mistaken, been awhile, attaches on the driver side reinforcment bar that runs across the bottom of the rad and is quite difficult to install. I leave my shroud on the rad and fight with the fan bolts when pulling the engine. Much easier. Alan
