OK, now I hope that I didn't just spend 5k + on an engine that gets a best of about 285 HP. Now when I could have bought a Cheeby box engine with 330 HP for what, 2k?? Tell me it ain't so Joe !! These numbers are not what I was thinking his engine would do. Considering it's pretty close to what I'm almost done building. < Mike >
Build it fast, build it right, hold On TIGHT !!! |
RR67GTO,
Those are not your numbers...there for runningbwdog. I'll do you engine today.
Carburetor building & modification services Servicing the Pontiac community over 25 years |
Shaker455,
Thanks for doing a desktop dyno on my engine combination. I have a couple of questions. Is this rearwheel hp? I'm a little surprised because the factory rating for this engine before I had it rebuilt was 360hp. Of course, that is at the flywheel with no accessories. The new standard gives lower numbers. Would RAM Air style exhaust manifolds and 2.5" exhaust pipes up the hp and torque numbers. Thanks again, Mike
1968 Pontiac GTO 462CID, 4-Speed Manual, 3.55 rear. Aleutian Blue exterior, 219 Teal Blue interior. Chrome bumper, AM & 8-Track and Rally II Wheels |
Mike,
The numbers are at the flywheel or back of the engine not at the rear wheels. I used HP mainfolds and exhaust on your set up to get those numbers. What's holding you back is your funky valve size and you could use headers... Jeff
RR67GTO,
Here's your dyno numbers: I could not remember how many cc's 6x-4's are ( some where between 91-96 cc's) but I used 9.5:1 for a CR and I used small tube open headers, first is with the XE-268 then XE-274. Flywheel hp & tq Hp 367@ 4000 Tq 507@ 3500 Hp 399@ 5000 Tq 509@ 3500
Thank you very much for the numbers. It looks like the 274 would be worth the extra time. And, if I had the heads ported and done well it should put me in the 400 HP range which is not bad for an old guy like myself.
I'm also happy now that I decided to have the valves changed to 211 x 177 because I'd be looking at doing a complete new set of heads after learning more that I knew back then. Again, thank you very much. < Mike in Oregon >
No problem Mike
Here's 6X ported w/XE268 then XE274 Hp 406@4500 Tq 529@3500 Hp 437@5000 Tq 528@4000
Shaker455
I wonder if you could run the numbers on the 455 I am now building for my 67 firebird Balanced stock rotating assembly 211/177 heads that flow @ 265/215 @ .500 lift SRP pistons approx. 9.5/1 comp. Comp hydraulic roller ground to 230/236 1.5 full roller rockers Edlebrock Performer RPM Speed Demon 850cfm annular carb Have not got headers yet but will be 1.75 4 tube type with either 2.5" or perferably 3" x-pipe exhaust any recomendations on headers for a first gen bird?
67 Firebird Best time 1.53 60' [email protected] 1/4 [email protected] 1/8 3500lb. leaf springs |
That's a nice set up and I really like the flow of the heads. HAve you decided just where your going to keep this beast yet? I tried using a RPM intake under the hood of my 350 car after I had the first engine swapped for a warmed over 67 400. I learned how to put a dent in the hood from the inside out.
I'm keeping it under a 400 hood with a drop base and 3" filter but would like to do ram air setup may have to get a tall 400 hood need somone with experience with this stuff (ram air). Also really need to know what headers are best I have been looking at Doug's headers. Also are there any resonable aluminum radiators out there.
Hi shaker455 I have always wounderd how much hp & tq mine would show on the desk top dyno I have a 400 with fully ported heads xe274h cam 9.5.1 comp, rpm intake, headers, carb set up by the carb shop , dist set up by larry row. that is if you don't mind. Thanks alot Loren
Yeahhhh, that's more what I'm looking for. So now, I know what I need to get there. Sure I can run the engine as is and see how I like it. But, the season is over here for a while. Oe reason is I need to replace all that dired out S.Cali weather strip on the car because we get a lot of rain here. So, I can go for the few upgrades, have the heads ported and install the new cam. And, get the car ready for the spring by doing the weather seal and doing some upgrades with having the posi built (I already have everything ready to go) and replace the worn parts below the paint job. Thank you very much for taking the time to run the numbers for me. Good day friend and also the rest of you. And, of course your families as well. < Mike in Oregon >
Happy T day to you all!
455earlybird and macho t/a, I'll be glad to run some number for you guys! 455early, I need all of your flow numbers...not just there peak..also I need all the specs for your comp roller or give me the number and I'll look it up on there site. What is your bore size and what heads are you running? Loren, I need more info from you as well, Bore size, head #, head flow numbers,carb size, thanks Jeff
hey, here is your flow chart
wedge intake valve flow chart port No : 2 valve dia : 2.110 gross valve area : 3.497 stem dia : 0.341 gross stem area : 0.091 net valve area : 3.405 first intake flowscale value : 150.0 leakage% : 0.0% test pressure : 28 (L/D) ratio 0.05 0.10 0.15 0.20 0.25 0.30 0.35 valve lift 0.105 0.211 0.316 0.422 0.527 0.633 0.739 test flowscale 150.0 298.0 298.0 298.0 298.0 298.0 298.0 flowscale adj. 149.6 297.1 297.1 297.1 297.1 297.1 297.1 flowmeter 0.840 0.580 0.740 0.860 0.890 0.900 0.900 total flow cfm 125.6 172.3 219.9 255.5 264.4 267.4 267.4 leakage cfm 0.0 test cfm 125.63 172.33 219.87 255.53 264.44 267.472 267.42 test cfm/in 36.89 50.61 64.57 75.04 77.66 78.53 78.53 potential cfm 22.76 45.68 68.61 78.65 84.00 87.51 87.51 % flow rating 162.1% 110.8% 94.1% 95.4% 92.4% 89.7%89.7% This is the Correct Exhaust Valve Flow Chart port no : 3 vlave dia : 1.770 gross valve area : 2.461 stem dia : 0.341 gross stem area : 0.091 net vlave area : 2.369 first exhaust flowscale value : 158.0 leakage% : 0.0% test pressure : 28 (L/D) ratio 0.05 0.10 0.15 0.20 0.25 0.30 0.35 valve lift 0.089 0.177 0.266 0.354 0.443 0.531 0.620 test flowscale 158.0 158.0 318.0 318.0 318.0 318.0 318.0 flowscale adj. 158.4 158.4 318.8 318.8 318.8 318.8 318.8 flowmeter 0.410 0.750 0.510 0.590 0.670 0.700 0.740 total flow cfm 64.9 118.8 162.6 188.1 213.6 223.1 235.9 leakage cfm 0.0 test cfm 64.94 118.78 162.57 188.07 213.57 223.13 235.88 test cfm/in 27.41 50.14 68.62 79.83 90.14 94.18 99.56 potential cfm 22.76 45.68 68.61 91.87 97.89 100.57 100.57 % flow rating 120.4% 109.8% 100.0% 86.4% 92.1% 93.6% 99.0% the carb is a 750 cfm q jet the heads are 6x-4 I now this more than you need just making sure I give you the right info Thanks Loren |
also I have 1.65 rockers thanks Loren
Loren,
Sorry my friend wrong info! I need yourflow #'s per .100" lift...here's an example: Intake lift flow .100" 86 .200" 155 .300" 200 Every # you can give me for intake and exhaust ..
I'm lost All I know is whats on that flow sheet I'm not to good at all this stuff yetI will have to get some help to find this out.
#38
all i was told was they flowed 267 at 600 lift when I bought them. sorry wish I knew.
#39
Don't bother,
I'm just going to have to print off your info and decode it for a loss of proper words...LOL But I see some of the numbers I need there just not in the right order and it look like they did not use a standard lift number like .100"-.150-.200 etc looks like they went .105-.211 etc and it look like the total cfm list is your flow....ripping my hair out now!...LOL..I'll get it for you
#40
I need you bore?
.030 over? head #? carb size?
