Old 03-09-2005, 05:26 AM
nasty66gto's Avatar
nasty66gto nasty66gto is offline
Send a message via AIM to nasty66gto
They must of changed the casting a little
but the bell is so thick I wouldn't think twice about taking a die grinder to the starter nose area if needed it's all most 1/2 inch thick it would take alot to weaken it
as long as your crack doesn't go past the bell
I would cut it off and put the ultra bell on
you can cut the bell off the chevy unit your can getting and build it up as a spare just change the bell over when you needed it
If your not first your last
Old 03-09-2005, 05:41 AM
Half-Inch Stud's Avatar
...the cracked-case would be a good candidate for an ultrabell huh.
Old 03-09-2005, 08:53 AM
ejw's Avatar
ejw ejw is offline
does jw make a bellhousing w/ pontiac bolt pattern or will i need to get an adapter plate to mate trans to engine. also, how far back do you cut, i see it mounts to the pump. does anyone have any pics.
Old 03-09-2005, 10:12 AM
nasty66gto's Avatar
it comes with chevy and buick olds pontiac caddy aka bop
patterns
so if you ever sell it you can sell to chevy guys too
