Old 10-27-2002, 07:27 AM
bmpmdf bmpmdf is offline
Check your oil pump passage to block passage. I had a misalinment problem on a block years ago, and after polishing the passages in the block, discovered the problem. I had an SD455 pump and couldn't get more than 20lbs at a 1000 rpm idle. Double check the oil feed holes to bearing holes too. And don't forget to clean the crankshaft's oil passages and alinmentto the bearings. Also,what direction was your crankshaft turned and polished? I 've seen shops turn crankshafts the opposite way from the way it turns in the engine. If the crank is turnned or polished that way, it will eat bearings. What happens is there is material that is left sticking up like ,say teeth, that srubs the bearing. If you could see it under a microscrope, it would amaze you. To check your pump to block passage, get two studs to put in the block, then use machinist dye on the pump face, and slip it on while the dye is still wet. Push just enough to leave a tracible ink stain on the block. The opening in the block and pump can then be "ported" to match. Hope this helps.
Have A Great Day
Old 10-27-2002, 09:02 AM
Ray Cox's Avatar
Ray Cox Ray Cox is offline
Ok I need to stir somthing up..... whats this story about timing chain covers Im missing somthing?????? [img]/infopop/emoticons/icon_confused.gif[/img]
8.90 @157 mph 3424 LBS. 77 Trans Am All Steel, on 10" tires
8.30 @ 165 mph 3,380 LBS
Old 10-27-2002, 09:38 AM
Scott Misus Scott Misus is offline
[img]/infopop/emoticons/icon_biggrin.gif[/img]
http://forums.performanceyears.com/g...5526035811&p=1
http://forums.performanceyears.com/g...1&m=1056084611
Old 10-27-2002, 09:49 AM
Rick Lightfoot Rick Lightfoot is offline
HAHAHAHAHAHAHAHA!!!!!!!!!!!!!!!!!! [img]/infopop/emoticons/icon_wink.gif[/img] [img]/infopop/emoticons/icon_razz.gif[/img]
Old 10-27-2002, 10:43 AM
Bob Dillon's Avatar
Bob Dillon Bob Dillon is offline
Location: Gilroy, California, USA-Garlic Capital of the world!
Hoo boy! Here we go! [img]/infopop/emoticons/icon_razz.gif[/img]
"Democracy is a beautiful thing, except for that part about letting just any old yokel vote."
~Jack Handey, Deep Thoughts
Old 10-27-2002, 07:40 PM
Goatman Goatman is offline
On Vacation
The real challenge is to sit back and do nothing. Just like the kings..........
They'll talk all day, but when it comes to time show something, they all dissapear! LMAO
"Do you love me? Do you hate me? Ready or not....Here....I......come....."
Ja Rule
[This message was edited by Goatman on October 27, 2002 at 10:00 PM.]
Old 10-27-2002, 08:11 PM
Brian Baker's Avatar
Hey, Bruce! You coming down to splATCO? I finally got the Discomobile running again. Would be nice to share a brew with you after I lose out in the 1st round (LOL).
Old 10-27-2002, 08:58 PM
On Vacation
Brian, I may be there. I was at NED tonight for the last day ceremonies (where everyone tries to beak their sh*t!) and it was cold and started raining at the end of the night. I think I may be sick now! LOL Been a very long week.
I may show up just to see Misus'headers though. Who really knows. LOL
Ja Rule
