Old 03-13-2005, 09:49 AM
74t/a 74t/a is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by PONCHOSHOP:
Gonna piss some people off. I plug the bypass off & use delco or wix, and lee(in the past when they where available), never had a problem with 60lb gm pumps. </div></BLOCKQUOTE>
He is taling about the by-pass in the filter housing?????
It is not the same thing we are talking about.
Old 03-13-2005, 09:56 AM
Half-Inch Stud's Avatar
I used to plug the Filter bypass..now only sometimes block the bypass depending on:
The oil filter being Large&Remoted or
justsa PF24 on the adapter.
Old 03-14-2005, 09:21 AM
Region Warrior's Avatar
Forgot to mention that part. I believe the bypass valve in the o/f adapter lets unfiltered oil thru on acceleration. I installed a 5/16 plug in place of the disc. I have heard this can cause a cheap filter like Frams to blow out. I never tried this with an 80lb pump. Anyone else do this and what are your thoughts?
Old 03-15-2005, 03:36 AM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
The bypass valve will open if there is a high DIFFERENTIAL pressure across the filter. As in a clogged filter, or a restrictive filter for the amount of flow. The system pressure (ie 60# or 80# or whatever) has no bearing on the bypass opening. If the filter were a zero percent restriction, you would have the same pressure on both sides of the bypass valve. That's my take on it. I don't block the bypass.
