Old 10-20-2002, 12:20 PM
77 TA Black non T-top car..455 .30 over with all the goodies.
14.20 @98mph best on street tires smoking through the 60' :P
Mike
Old 10-21-2002, 10:50 PM
RossGN RossGN is offline
'74 SD455 Trans Am...I fly it from inside the garage to the driveway and then back into the garage.
Ross Little
Wichita Falls, TX
Old 10-24-2002, 11:31 AM
7t6fb 7t6fb is offline
NEWBIE here! I just got a 76 firebird with a 73 nose end 455 SD ram air hood 350 turbo trans with a B&M slap shift. that all i know about it for now.
Old 10-25-2002, 08:27 AM
schneidsd455's Avatar
schneidsd455 schneidsd455 is offline
74 SD 455 TA. 55k miles. auto, red with all red interior. 3.42 rear, A/C, deluxe interior, pw, front and rear console, decor package. I think I'm the eighth owner (I'd hafta look at all the copies of titles that I have. Just got it put back together. Lots of $ and time and lots of fun.
Jeff Schneider
Alliance, NE
Old 10-26-2002, 05:34 PM
Reed '75_T/A Reed '75_T/A is offline
I'm rockin' a white '75 Trans Am with a 400 and th350. It's currently getting bored 30 over with a Comp XE268 cam, #13 heads and a bunch of other goodies. I'm also switching to a 3.08 rear from an '81 TTA and I'm switching the front end to a '72.
Ambition is a poor excuse for not having sense enough to be lazy.
I'm Shane Reed. I don't need a signature.
Old 11-08-2002, 10:25 PM
millennium200 millennium200 is offline
I have a silver 75TA 400,4speed I purchased new. The car has 77000 miles with no rust or dents, however the paint on the top and hood was very faded so I am in the process of a total rebuild. I replaced the original motor with a motor that I rebuilt from a wrecked 68 GTO about 1978. I drove that motor about 55000 miles. I still have the original motor with only 22000 miles still setting in my shop. I have finished another rebuild on my 68 motor bored 30 over,Eagle rods and Eheads and a lot of other goodies that I hope to put in the car tomorrow. Then the car goes back to the paint shop to finish the paint. I hope to have it ready for the 03 power tour.
Old 11-09-2002, 06:09 AM
I have a couple of cars which I don't drive and are awaiting restoration. These include a wrecked 73 T/A red 4-spd a/c, and a 74 SD455 T/A. I also have a nice red SD455 T/A.
The car I drive is a red 74 T/A 455 with red interior. I am the second owner, it was off the road for fifteen years before I bought it due to engine problems. The owner and his mechanic ended up in court over the car. The owner spun a rod bearing back in 77 or so, and had an engine builder put it back together with a Ram IV cam. After the car would start to warm up, a couple of lifters would start making a horrible racket. The mechanic blamed it on the cam, so the owner paid the guy to install a stock cam. With the new cam, it still made the noise, so the owner parked the car and went to court.
I bought it in 1995. Upon checking it out, I found it had several bent pushrods. I replaced them and solved the problem for a few years. Then, on the coldest day of the year here in NC, my wife's car wouldn't start. She decided to drive the T/A, cranked it and raced the engine at 10 F, and sheared the oil drive rod. Luckily she cut it off before any severe damage occurred.
I had another 74 455 with low miles already out. I freshened it up with a mild Wolverine cam, fresh valve job, and dropped it in. I also installed the flowmaster exhaust system that uses the one muffler behind the rear axle. I selected the cam based on an engine dyno program. It has an incredibly flat torque curve, but peak HP occurs at only 4300 RPM. It is a blast to drive on the street.
It is probably a #4 condition, but the body is excellent. Paint is dull and the interior shows some signs of wear. I have a 15 year old son, and I'm hoping to do an amateur restoration over the next few years.
Mike
Old 01-29-2003, 04:54 PM
KevinDush KevinDush is offline
Well, I suppose I should update this since the last time I responded to this (btw I was the first to respond to this topic) was way back on May 12, 2000.
A few things have changed... mainly that the car is no longer white, but in fact rather black. I did it up like a LE or SE, put Hurst t-tops in it, and all the gold interior goodies.
I have also since put the 455 (462) in it and decided against the overdrive automatic transmission.
Also, I'm still working on that Web page that I mentioned, but the address has changed to http://www.sensible-net.com/kevin/
You can see lots of pics of my car as well as of my fiance's '78 T/A that we are working on (under "Noelle's T/A").
Later,
Kevin
__________________________________________________ ______________________________
1976 Trans Am, 4050lbs, 462", TH400, 3.23s, 255/60R15 street radials, 13.68 @ 100.35.
Kevin's Trans Am Source - Check out my site: it's incomplete but has lots of pics of my car.
Old 03-02-2003, 09:09 AM
Brew Brew is offline
I recently aquired a black 76 455 4speed T/A. The block is out of a 1970 big car, but everything else looks to be original. Supposedly a fresh performance rebuild on the motor, tranny, and rear, but I havent received any verification yet.
It's in about #2 condition right now, but I'm pretty sure I can get it to a solid #3 with just a little time and effort.
I havent played with any second gens since high school, and no f-bodys at all in about 12 years. I'd forgotten how cool these cars are!
67 LeMans vert w/462
68 GTO bone stock
Old 03-02-2003, 09:11 AM
Oops! I meant to say it was in #4 condition right now, and I could IMPROVE it to a #3.
68 GTO bone stock
Old 03-10-2003, 04:09 PM
dragracer56 dragracer56 is offline
Here's mine........The Rare Bird
.2001 Pontiac National Champion
.1975 Silver Pontiac Trans Am
.400 C.I.Pure Pontiac Engine Built by Powersource Racing Engines Fox Lake Illinois
.Hooker Headers
.Flowtech Warlock Mufflers
.Autometer Gauges
.Richmond 3:90 Rear Gear
.Compettion Engineering Subframe Connectors
.Compettion Engineering Drag Shocks
.Hurst V-Matic Shifter
.TCI Street Fighter 3000 Stall Torque Converter
.MSD HEI 75,000 Volt Ignition
.Taylor Spiro Pro Spark Plug Wires
.Moroso Blue Anodized Valve Covers
.Holley 600cfm Carb
.Holley High Performance Fuel Pump
.Edelbrock Pontiac Performer Intake
.B.F. Goodrich Tires
.Stock Interior
.Best E/T 13.816 @ 100.02 MPH
.2004 GreatLakes Dragaway Street Class Champion
.2003 GreatLakes Dragaway Street Class Champion
Old 03-11-2003, 07:17 AM
form74's Avatar
form74 form74 is offline
74 Formula Transplanted from AZ, now resides in ILL. A Driving restoration, have collected enough parts to build 1/3 to 1/2 of another car, but always looking for nicer part.
http://pontiaconline.com/members/117
Addicted to Buying Nicer Parts for a Future Restoration even thou I have every part for it Already.
74 Formula
3 inch exhaust with x-pipe
Quadrajet done by Cliff
3:42 gears
12.061 @ 110.74
12.092 @ 112.43
12.128 @ 111.71
461 stroker
Edelbrock 87 cc dport heads
Performer RPM
Old 03-11-2003, 02:52 PM
LeighP's Avatar
LeighP LeighP is offline
My Trans Am is a 1976. Originally a 455/4 speed, it left the factory Starlight Black with black deluxe interior.
During its life the car has lost a few parts, due to careless previous owners, no doubt. I believe the car was imported to Australia without the 455 and 4 speed, as it was originally converted to Right Hand Drive and set up as a 350 Chev with TH350 auto. Its currently painted light blue. I've been doing a driving restoration on this car since I bought it, my aim is to have a reliable daily driver. I plan to restore it properly a few years down the track.
I had a lucky find the other day, a fellow Trans Am owner who had the bad luck to write-off his 74 T/A. If things go well, I might be able to buy the wreck ... which has a 455 and a 12 bolt Posi.
I also have a very tidy 1970 Camaro RS/SS with TPI 350/4 speed and 12 bolt posi.
Regards,
Leigh
1976 Trans Am
1970 RS/SS Camaro
Sydney, Australia
Regards,
Leigh
Pontiacs I’ve owned….
1960 Laurentian 283
1963 Laurentian 283
1976 Trans Am 400
1977 Trans Am 400
1951 Chieftain Flat head 6
1967 Firebird 400 convertible
1967 Firebird 400 coupe
1979 Trans Am 403
1971 Formula 455 (clone)
1969 Firebird 350
1968 Firebird 428 manual.
Sydney, Australia
Old 04-07-2003, 01:40 AM
76esprit 76esprit is offline
I fly in a 1976 Firebird Esprit. 350 v8 engine 3 speed auto trans. It has a 2bbl Rochester carb which has been giving me problems since I bought it.
I've only had it a few months, so I haven't had the time to do a 1/4 mile run.
Red interior and exterior, without the tail fin.
It has a lot of work to get it to where I want it, but the price was right when I bought it ($550), so I couldn't pass up the opportunity for this classic birdie.
Old 04-08-2003, 02:27 PM
Mark C.'s Avatar
Mark C. Mark C. is offline
I'm the original owner of a 76 TA. Black on white. 455 4spd car. Other than the 455 option ordered very few other options. Tinted glass, conveneince light package, roof drip rails and chrome trim package. 24,350 showing on the odometer. In the process of redoing it now. Sat outside covered for 1 1/2 years, in South Carolina. Rusted up the undercarriage somewhat. Trying to get the motor together currently. Under side is done,interior needs minor touching up and a paint job.
Mark C.
70 Bonneville 455, survivor (Third Owner)
Old 04-09-2003, 02:17 PM
tony_42_00 tony_42_00 is offline
hey! 76 firethorn red...400 all original, my dad bought it new in Cincy in 76, great shape...not a sharper car on the road
Old 11-20-2003, 05:49 AM
lilphillie78 lilphillie78 is offline
I just picked up a 76 trans am that was sitting in a field for 4 years with no shaker on it... Water all through the carb. oatmeal looking substance in the intake Edelbrock intake and carb by the way. Rust in the intake ports on the head rust on the massive rocker arms, i cant get the engine to move, the lady that told me to go pick it up said it was a new crate motor when she parked it in that cursed field 4 years ago, but it dosent move. The parts dont even look like they've ever moved, the odometer says 09,514 so i dont know... the body is all screwed up and i don't know if it's a pontiac motor at all, but i hope it is. It's been repainted at least once, the origional- Whatever color Maroonish Red- and the block is a strange light bluu, along with the water pump and the valve covers look like they also want to be the same color, but nature got to them... If this motor dosen't work out, i've got a 472 sitting in the garage all lonely, and built up as much as it can be... Evil thoughts Evil thoughts
sex should be like driving a honda: slow, obscene, and loud enough for your neighbors to hear
  #38
Old 11-24-2003, 08:56 AM
troy meyer's Avatar
troy meyer troy meyer is offline
Wow, there is allot of 76's on this thread,
I currently daily drive a 1971 White with black standard Trans Am. Original 455ho and 4 Speed are long gone. Replaced with a 1970 formula ys 400 and matching t-400. 3.73 posi keeps me in the gas station line but it is fun to drive.
Troy
Troy Meyer
Fort Mitchell, AL 36856
  #39
Old 11-24-2003, 01:28 PM
transam_kahuna's Avatar
transam_kahuna transam_kahuna is offline
I've got the earliest known 1974 SD-455..cameo white,white/black int. 69k miles next in line to paint shop..also another 1974 SD-455, 2nd owner,red w red/black int.58k miles presently in paint shop and finally a 1978 TA with a 70 judge RA IV engine with a doug nash 5 speed..my top speed runner..I did 140 mph with OLD engine..with RA IV I've done about 152 mph before I ran out of road
1970 Trans AM RAM AIR III 1974 SD-455 TA earliest known
1974 SD-55 TA
1978 RAM AIR IV TA
1967 USMC M-151A1
1972 USMC M-151A2
1978 TA
ram air V heads waiting to be run
2000 MT-500 Harley Davidson military motorcycle 1 of apx 169
1991 USMC KLR-250 "devil dogs" X's 2
1979 M-151 US Army Hooah!
1975 A-350 Condor Swiss army motorcycle 1 of 3000 made
1974 A-350 Condor Swiss army " " "
1966 M-274 A2 mule USMC
"Gort, Klatu barada nickto"
  #40
Old 02-06-2004, 10:09 PM
1975BlueTransAm 1975BlueTransAm is offline
I have a 1975 Pontiac Trans Am. I bought it about a year ago for $800 (a really good deal from a friend). It was dark blue when i bought it and it,s is now Cosmic Blue. I changed the stock 2.56 gears in the rear end to 4.10s, put a B&M shifter and shift improver kit on the tranny, and rebuilt the motor in the past 4 months. the motor now has about 9 to 1 compression with a comp 268H cam, roller rockers, and MSD ignition. I havent been to the track yet, but i am hoping to be turning mid to high 13s. Next week i am going to put my decals on it and it will look even better.
