Old 10-30-2002, 09:19 AM
Roy Zink Roy Zink is offline
Right now I'm running an Accell Dual Point.....can this distributer be converted to a Pertronix or do I have to go back to the stock dist?
Roy
Old 11-01-2002, 03:48 AM
60man's Avatar
60man 60man is offline
Gonzo: Thanks for information. I will contact Pertronix. Aside from the wait it performs great. I use it on my race car and it does fine. HEI is tight with a Tri-power.
RetroJoe. What's the problem with the lobe sensing Pertronix? It would seem the fewer parts the less chance for failure.
Outlaw Pontiac Racers Association
"For Those Who Live The Legend"
ECM member.
MANDRA
Old 11-03-2002, 07:20 AM
retrojoe's Avatar
retrojoe retrojoe is offline
From what I've been told, if there is any type of wear on the dist. it will try to correct it's self while running causing it to run rough. I have and old email about this setup that I will see if I still have and mail it to you.
My other life has meaning....
"It beats pickin' cotton and waitin' to be forgotten"
Old 11-03-2002, 07:27 AM
GONZO's Avatar
GONZO GONZO is offline
Haven't had this problem in any pertronix I installed, My suggestion would be to inspect the distributor before installing it, why would anyone put a worn distributor in their car is a mystery to me.
Under normal conditions (good distributor) pertronix works fine.
http://www.kingofgtos.com/index.htm
http://www.stockappearingdrags.com
Come on get off that lawn chair and drive that car like it was meant to be driven.
69' 400 RAIV Judge Conv... 12.86@107 Factory Stock
69' 400 RAIV Trans AM .....12.48@110 Factory Stock
69' 400 RAIV Judge HT..... 13.07@104 Factory Stock
73' 455 SD Trans AM........13's?? not run yet
66' 455 GTO Convert.........12.20@112 non original
63' 421 SD Catalina...........restored fast as h*ll
