Hello guys what do you think would be a good combo to run for a tranny and converter in this car and engine combo??I'm getting ready to finish the car for spring and need a tranny..Any suggestions
Heres the car 1979 T/A 3165 lbs w/me in it and full fuel cell Moroso drag springs up front Calvert Caltrac Bars w/Calvert split springs in rear with QA1 12 ways at all 4 corners 29x10.5/15 slicks on rear w/15x10" Pro Stars 15x3.5 Pro Stars up front 12 point cage 9" Ford w/4.11 and a light spool Anything Else just ask Heres the engine 408ci 4.160 bore 3.750 stroke stock 350 crank 10/10" stock rods/ARP bolts peened/polished Flat top TRW's lightweight pins Custom ground Solid Comp Cam [email protected]" in/[email protected]"ex 567"in/587"ex 108 LSA/ICL 1.6 roller rockers Ported "16" flow 282cfm @ 600" in / 210cfm @ 600" ex Compression 12.8:1 Pro Systems 950 HP 1 7/8 Super Comp headers Full Mandrel Bent 3" exhaust Ported T2 intake Full MSD ignition Anything else just ask me This motor dynoed last summer made 523hp @6000 rpm and 502 ft lbs @ 5000rpm I still have dyno sheet so if you need to know more torque specs I can tell you.Thanks for any help..Also does anyone have a idea of what this car should run roughly.?? " If I ain't Loggin' Hard then I'm Drivin Hard " |
