Old 03-23-2009, 06:41 PM
JC455 JC455 is offline
BUMP!!
John
IG: @crawdaddycustoms
YouTube: https://www.youtube.com/channel/UCK9...Nc_lk1Q/videos
Old 06-10-2026, 10:20 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Update-cleaning out the garage a couple of weeks ago so I could bring a car back home form the shop and found this project thought I would try and finish. I had bought some trap doors from Canton and had a fabricator add some additional baffles with them. Mocked up a 22ga sheet metal tray then bought some 18ga sheet to duplicate it. I bent the front edge up a little so it can drain back in form the front-a little lip where milodon had cut then added the sump. Just nor sure where to add any additional drain holes. 5 trap doors.
ID:	671523   Click image for larger version
ID:	671524   Click image for larger version
ID:	671525   Click image for larger version
Skip Fix
Old 06-10-2026, 10:27 AM
Skip Fix's Avatar
Here is a Canton pan F body pan slightly different top trays on them. On on the pump gas 455 in the TA second slightly overlapping tray on the 500!A but I had the sump deepened 1".
ID:	671531   Click image for larger version
Skip Fix
The Following 2 Users Say Thank You to Skip Fix For This Useful Post:
Old 06-10-2026, 10:31 AM
Skip Fix's Avatar
Here is a GTO pan that is deeper from Canton but I extended the sump forward like an F body pan and then extended the top tray. It is on the 0.060 455 motor I just dynoed. Have a smoke machine on the way to be sure it is not the rear main leaking.
ID:	671534   Click image for larger version
ID:	671535   Click image for larger version
ID:	671536   Click image for larger version
Skip Fix
The Following 4 Users Say Thank You to Skip Fix For This Useful Post:
