Sorry i am a little confused too. Advance has a Neapco brute force without zerks for 14.94. is this the one i am looking for? Thanks - ryan
[email protected] / 1.843 60'/ 3980 lbs 1964 corvette roadster 1968 corvette roadster 1962 corvette "equal rights, not equal things" if you want to know the future, read "atlas shrugged" I dont race a 4spd because it is easy, I race a 4spd because it is hard.
I didn't look at the packages, or install the joints, so I can't say for certain that they were Brute Force joints, or some imported "knock-off". They did fail miserably, causing considerable destruction and expense. This also occurred back around 2001, not sure if Advance even sold "Brute Force" joints at that time?.....Cliff
1976 LeMans B09 Freeway Enforcer, 455/M40 Smokey 1977 Trans Am, 400/M21 Black/Gold Bandit. 44K actual miles 2017 Sierra SLT 1500 Z71 4X4 ![]() 2019 Canyon SLT Crew 4X4 ![]() |
As with most other things with this hobby, insist on and use the best parts, especially for driveshafts and diff's. Pontiac engines in particular use/rely on massive amounts of torque to effectively run with/outrun most other makes. This can be incredibly hard on drivetrain parts, to date I've broken EVERYTHING behind my 455 engine, including blowing two 8.5 stock carriers to bits on two consecutive passes. It looked like someone took the cover off and threw a hand grenade inside, blowing the spider gears into a million peices and leaving a fist sized hole in the carrier on the last failure!......Cliff
Just for kicks I went to Advance Auto and got a Brute Force joint.
It's the 1310 series. I'll post some pics later of both the Precision joints and the Brute Force.. Has anyone got pics of a Lakewood.Mark Williams,etc... Must admit this has become interesting to me... I will say that I found out the Precision SS greasable joint is still cross drilled where as the non greasable is only "partially" drilled.. Later This is the box the BF joint came in...
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
Troy, I think that is the Neapco joint I use. The guy that did my drive shaft told me it would hold up to anything I could throw at it. So far, so good.
Thanks Darin.
Ok I'll post the pics of joints. The one with the RED seals is the Brute Force. Then I have one of the Greasable(235) & the Non-greasable(234) joints side by side. The 235 is cross drilled for lube the 234 is not. In comparing to the BF joint the Bf joint had more metal in the machined area of bearing jounal. But the 234 joint had a thicker wall at the end of journal..trade off !!?? I would still like to see a "solid" Spicer,Mark Williams,etc. to compare. I think I'm going to try the Brute Force along with the 234 Precision joints. I included a pic of my destroyed front joint just to show "where" it failed.. This joint was "regular" Precision joint... ry57pont: If you are street driving I believe the Precision Geasable SS or Non-greasable SS joint will do as well as the Brute Force joint
I went to a spool and cured that but then managed to break both axles in one launch ...Moser cured that. I have only lost one u-joint though even with them not being 1350's...I also think pinion angle has a lot to do with stress on the joints. I also use Moroso u-joint girdles.. And I agree TORQUE is where it is at.....
Spicer 1350 is what you need. Get it and .................... forget ir.
1978 Pontiac Grand LeMans.......out next year Previous - 2001 Jerry Haas-built P/S Grand Am - former WJ car, Hoffman Racing 535" IA2, Tiger Heads/Intake, Single Dominator, PG Best ET: 7.776 @ 175.94, 1.096 60', 2375 lbs. |
In my case a two piece driveshaft....
