Old 02-15-2007, 11:31 AM
Brian Baker's Avatar
If aluminum rods were used, I think it has a good chance at surviving. I think I would have filled the block to at least the bottom of the water pump holes though, especially considering the HP level.
Old 02-15-2007, 11:33 AM
Oh...and those intake ports are "purdy". Did you have to go to an offset lifter? Looks like the pushrod holes were moved over quite a bit.
Old 02-15-2007, 12:25 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Larry don't throw them away just hog them out more from your 180cc port! But then that will hurt that "small port velocity" everyone talks about with D ports because the ccs will get closer to E head/ported KRE size.
Looks like head bolt tube as well as pushrod tubes and all that epoxy on top to raise the port, and just a nub of a guide.Bet it's at least 215cc. LOTS of good shaping and grinding there, very nice.
Man my buddies 48s were barely 200 cfm on the intake side, took some moderate porting to even get them to 225.
Old 02-15-2007, 12:29 PM
Jack Ferris's Avatar
Jack Ferris Jack Ferris is offline
Originally Posted by Larry Navarro
.......think i'll throw my d-ports out the window.....
Ya send them out to Utah and I'll make sure they get tossed..........On my car!!!!
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 02-15-2007, 01:01 PM
Larry Navarro's Avatar
Now...Now Skip, lets not turn this into an "apples to oranges" discussion.
Everyone knows that "small port velocity" propels big 4200lb "boats" to mid-11 e.t.'s.
Old 02-15-2007, 01:18 PM
scott70's Avatar
scott70 scott70 is offline
127% VE? Very nice!!!!!!!I hit 97% on my last engine and I thought that was good,lol.Very impressive.I want one,,,,,,,,,,,,,,,(whine).
Old 02-15-2007, 01:29 PM
J.C.you's Avatar
J.C.you J.C.you is offline
very nice head work. i know how much grinding that is involved in those heads. i would guess you have well over 300 hrs in the heads?
Jim, have a flow sheet and dyno sheet you would post?
1966 GTO dragcar
1966 GTO Ragtop
1969 GTO Judge RA lll, auto
1970 GP SSJ
Factory stock oval track car
Old 02-15-2007, 03:48 PM
JKrull66's Avatar
JKrull66 JKrull66 is offline
Send a message via AIM to JKrull66
Kool Pics Jim, Glad you decided to share.
Like your site, always wanted some R.A.C.E. heads........
Beers Bikes Babes and Pontiacs Rule!!!
63 Lemans in the 9's race
66 GTO HT Cruiser
06 Triumph Rocket III TURBO! 2300 CC Bad boy
KTM 525 Dirt Terrorizer
POLARIS 900 RZR
10 GMC SLT Duramax Haul anything anywhere
http://www.facebook.com/profile.php?...app_2392950137
Old 02-15-2007, 03:51 PM
Skip Fix's Avatar
I just wanted to note these are not those same "small" D ports making big HP before you hard core D port fans start suggesting they are! Kind of like the 310+cfm KRE heads aren't 185cc! It takes a larger port to move that kind of air and make that kind of HP no matter what the material or head that is started with. Obviously a well done head!
I'll bet ALOT of hours and "black boogers" from all that porting!
So got any chamber pictures to see what they look like using such little timing?
Old 02-15-2007, 05:35 PM
NHRASuperStock455SD's Avatar
NHRASuperStock455SD NHRASuperStock455SD is offline
Send a message via AIM to NHRASuperStock455SD
Hey Jim,
Good Job! Looks like very good work. What minimum CSA did you end up with? It looks like you did a very very good job around the push rod.
Lynn
Old 02-15-2007, 06:21 PM
Obviously Skip, I think that everyone would agree that 800HP isn't going to be achieved with "small" port D-heads and aren't suggesting that it can.
Let's be honest, would anyone have ever bet that a person could produce those numbers from a iron "doorstop"?
Perhaps "Gach",....but not the regular crowd here.
I'm sure Mr. Robertson has amazed everyone with the numbers and workmanship on those heads.
Old 02-15-2007, 06:58 PM
Wareagle's Avatar
Wareagle Wareagle is offline
Thumbs up
Very nice Jim--PONTIAC POWER.
Old 02-15-2007, 06:59 PM
NICE..... wonder what you could of got if you started with a KRE?
Old 02-15-2007, 07:17 PM
SweBird SweBird is offline
Wow! Nice job!
My cars: http://www.garaget.org/formula
SWEDEN
Old 02-15-2007, 08:06 PM
punisher#1's Avatar
punisher#1 punisher#1 is offline
outstanding job jim. you gonna put that in a true 10 car with a little juice and come play in dallas this year?
looking forward to seeing you up there again
i got something for them dallas boys this year.
'78 Ford Fairmont 526ci pontiac; true 10.5 tires and stock suspension.
5.14 @140.5 w/nos; 8.86@151 all motor.8.17@172 1/4 mile w/nos
Old 02-15-2007, 08:45 PM
Jeff Kinsler's Avatar
Jeff Kinsler Jeff Kinsler is offline
They are some awesome numbers. Congrats.
540 c.i. Ultra Street Combo
Tiger Heads with Tiger Intake
Induction Solutions fogger with .046s
1.079 4.52 155.15
3000 lbs
7.77 @ 169 1/4 Mile (2015) with EHTTFMF!!
7.17 @ 188 1/4 mile (2024)
Special Thanks to:
Ron at Rhodes Custom Auto
Butler Peformance
Jim Hostler's Transmissions (HOSGTO) on here
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
Old 02-15-2007, 08:57 PM
gearbanger's Avatar
gearbanger gearbanger is offline
Probably not nearly as much, because KRE D-ports are only replacement heads for street cars. They were never intended to make horsepower, only to have a place to mount your original valve covers.
  #38
Old 02-15-2007, 09:03 PM
screamingchief's Avatar
screamingchief screamingchief is offline
Trust me when I say this,,,JD aint "just whistlin' dixie" with that comment!
That thing is loaded for big game!!!
It's all double top secret/cone of silence type stuff.
If I told ya'll any more,JD and Steve would put a contract out on me...
This space for rent...
In the meantime,check out the cars HERE.
  #39
Old 02-15-2007, 09:05 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Once again the double the cfm = approx HP myth is dispelled.
john
  #40
Old 02-15-2007, 09:09 PM
Jim Robertson's Avatar
Jim Robertson Jim Robertson is offline
We used C-16 VP fuel
The intake port is 218ccs good eye Skip.
Yes we hit everything - water, air, bolts, and pushrods. Pushrods are moved a little over .200".
Very light aluminum GRP rod.
Engine is now in a 71 T/A. It ran low 11s at 3565lbs with the mild 462 that is pictured with the Warrior on the website.
300 hours...Probably close I lost track a long time ago. :-)
Min cross section is right at 2.85sq in
Jim
