Old 07-31-2007, 09:13 PM
Building any brand engine in the 540 cube range to the 1000hp NA is going to cost about the same in the long run. SBC to not even near that level, even more (and you would need 2 or 3 to get thru the season). A roots blower might be less but would still need very good heads, a turbo setup would make way more than 1000 hp for same money(as 540) with less cubes and less head work.
Old 07-31-2007, 09:26 PM
Wareagle's Avatar
Wareagle Wareagle is offline
Talking
Were does this guy hang--Street legal 79 T/A -No Nitrous--537 cu inch-950 hp 7200 rpm Tiger heads--IA II Aluminum block.
ID:	99850   Click image for larger version
Old 07-31-2007, 09:53 PM
Tom Vaught's Avatar
Boost Engineer
John's list:
Heads - 8k with titanium valves, springs, seats, guides, head bolts and shaft bars (that is being conservative)
(Substitute E-heads at 300 cfm for 3K and Vortech Ysi blower for 3K Total = 6K Savings = 2K
John's Intake - 4k with 2 dominators (box stock no tricks)
Substitute Victor/ 1050 Dominator (blow thru carb) and
dominator bonnet $1500.00 Savings = 2.5K
block - 4k machined
crank - 2.5k (With less rpm a 1K Forging will work)
Saving 1.5K
rods, pistons, pins, rings and bearings - $2k
oil pan, oil pump, vacuum pump & valve covers - $1.5k
Supercharger Cog belt drive, water pump, crank trigger and balancer - $1.75k
cam, lifters and push rods - $1.3k
flex plate and starter - $.4k
dist, plugs, wires, cap, rotor - $.2k
oil and remote oil filter - $.1k
head and valve cover gaskets - $.2k
custom headers - $2.5k
Possibly 1K headers saving 1.5K
misc shipping - $.5k
dyno - $.5k
Grand Total - $29,450.00
Total savings 7.5K plus less maint due to lower rpm of the blower engine. Engine = roughly 22K
Tom V.
Lots of SB Ford Renegade racers making 1100 hp in that class.
Old 07-31-2007, 10:32 PM
tempest455's Avatar
tempest455 tempest455 is offline
A SSRE, Reher-Morrison, Musi etc. big block Chevy motor making over 1,000 HP with all aftermaket stuff is still going to cost well in excess of $20K. Probably more like $25K all said and done. A buddy bought a SSRE motor in one of his ads. By the time all the "hidden" fees were added, it was a lot more than the ad.
Tempest455
Old 07-31-2007, 10:50 PM
goatroper's Avatar
goatroper goatroper is offline
Not to get off subject, but what would keep "as cast" Tiger's from supporting 1000hp NA? With a sheetmetal intake, two dominators, GOOD headers, and lots of compression. You can get them ready to go for $5,650. What am I missing?
Old 07-31-2007, 11:05 PM
adam woodmancy's Avatar
adam woodmancy adam woodmancy is offline
Send a message via AIM to adam woodmancy
Just a little FYI
My 555 conventional headed Huntsville Engine motor made just 900 for 17k and some change. but thats with every option except the big chief upgrade and billet crank. Base package 555 is 13 grand.
Dart Block
Brodix BB3X CNC heads
Brodix/Sonnys intake 4bbl
SRP Pistons
Jesel Shafts and Belt drive
Oliver Billet Rods
comp 7/4 swap roller
Lunati Pro Series crank
aerospace vacuum pump
crank trigger
csr pump and starter.
Was told it would be about 3 grand extra to use big chiefs/big dukes
Old 08-01-2007, 03:28 AM
Colin's Avatar
Colin Colin is offline
Location: The ObamaNation we once called the United States of America
I dont know.........but that door bar doesnt look NHRA legal.
"It is foolish and wrong to mourn the men who died. Rather we should thank God that such men lived."- General George Patton
"Perpetual peace is a futile dream."-General George Patton
"I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them."-Thomas Jefferson
"Any society that would give up a little liberty to gain a little security deserves neither and will loose both."-Benjamin Franklin
Old 08-01-2007, 05:12 AM
John Langer's Avatar
John Langer John Langer is offline
My buddy had BES build him a 638 bbc. It made 1075 hp and cost right around 14k out the door, dyno tested. Be careful about the ssre, rm and schmidt engine horsepower claims, I have seen them down approx 60+ claimed hp.
Old 08-01-2007, 09:10 AM
D. Miles's Avatar
D. Miles D. Miles is offline
A friend of ours bought a Shaffirof "BIG DUKE" 555 carb to pan for $14,500.00, with a consevative tune (too much jet/low timing till after a few runs) made 1006 HP on gas! It ran 9.20's in 3200 lb Monte SS. Started to do some tuning to carb and inch timing up and got an 8.91 out of it in bad air. Would have made more HP on alky with the 14:1 compression. He sold the whole motor for $9,000.00. Ahh someone has 1000+ HP for under $10,000.00 Thanks D. Miles
Going TurboCharged!
Old 08-01-2007, 09:13 AM
Last year I went 8.61 with 975hp weighing 3200 lbs.
Old 08-01-2007, 10:37 AM
the way its been explained to me a they can pretty much make the dyno sheet say whatever they want by manipulating the load and a few other factors. my 898 hp 555 ran within 7 hundredths of my buddys big chief 598 from shafiroff that supposedly makes 1120 in the SAME car. I know Todd Ewing from Huntsville Engine told me that they but a massive load on my motor, which explains the low number. Its a real world 898 hp. He said if i thought i needed a dyno sheet with a big number he could set it up, but really all its good for sitting around bragging with your buddies.
Old 08-01-2007, 11:21 AM
I think it will take heads with intake flow approx 480 cfm@ 28 inches h2o to get 1000 hp. Yes/No? I think I did my math right!
Old 08-01-2007, 11:28 AM
John Bailey (GTOKID)'s Avatar
John Bailey (GTOKID) John Bailey (GTOKID) is offline
no.
Old 08-01-2007, 11:48 AM
another vote for no, I made 991 with a single 4 intake, 525 cid and heads that flowed 380 @ 28". (2) 4's on a tunnel ram would have made 1,000.
Old 08-01-2007, 12:13 PM
greggutknecht greggutknecht is offline
It goes back to a properly shaped port is more important than big flow#
Old 08-01-2007, 10:23 PM
I used the formula in Jim hands book for estimating airflow required for horsepower. It seems to work with lesser motors. Guess I can throw that out the door. I didnt think we were there yet on head flow #s(485) Thanks
Old 08-02-2007, 10:14 AM
John I checked the formula last night! I did the correct math and came to the conclusion that the formula doesnt have a VE factor or air correction factor. The formula predicts you at 790 lol. It obviously doent account for any sonic "tuning" effects in the intake and exhaust scavenging/ tuning.
Formula cfm@28"H20 x .26 x # of cylinders = HP estimated. The question remaining in my head is if the formula is perhaps correct, are your 380cfm heads actually getting 476 thru them in actual operation vs the flow bench ? Think I'm going to have to look up some of my other airflow data to see if whats published in Jims book is totally wrong or if it is just the minimum expected at Jims RPM levels. All input appreciated!
  #38
Old 08-02-2007, 11:05 AM
you cant race math formulas.
  #39
Old 08-02-2007, 11:25 AM
"you cant race math formulas" you wont get an argument from me on that for sure John. Nothing like the real world but sometimes we like to see the #s too.
I've often said at work "I dont care what the book says, this is what works" and it certainly applies to racin.
  #40
Old 08-02-2007, 01:04 PM
Billy177's Avatar
Billy177 Billy177 is offline
A chevy, but an intresting article. I doubt that will last long.
http://www.hotrod.com/techarticles/e...est/index.html
70 GTO
462 E-Heads TKO-600 9-Inch/3.60's
