| The Body Shop TECH General questions that don't fit in any other forum |
Just to add....
On some parts that have a heavy rust coating and hard to grind, or I just don't feel like grinding, I have used muriatic acid (Hydrochloric acid) to eat the rust then rinse with water to neutralize. Let it dry then wash with phosphoric acid to remove the little bit of flash rust that develops,or sand to remove. This is useful on frames and those hard to grind areas. It can be found at Home Depot too, or your favorite swimming pool supply store. |
Yes you are right on both counts there too. Although I have no personal experince with POR 15, If you apply it over rust or any type of similar coating that claims to neutralize it in a similar fashion, It is only a Band Aid fix at best... Although I have no experince with POR 15, If it is So great why is not being in industrial applications like Bridges??? Especial ones in or near salt water??? I am Not saying its a Bad product just that the best way to treat rust is to completely remove it and then coat the bare metal accordingly... Thats my worth
http://www.masterseriesct.com/wst_page3.html
Greg Reid Palmetto, Georgia |
Once it's dry, the next step is applying your DP90LP. |
When you do it that way does risineing with water leave a film of any kind??? what did you use besides a rag to clean the surface??? Any chemicals??? I have never used the DX520 wich may have been my problem but I always had issues until I started using acetone to neutrilze the DX579 and Red scotch brite. The red scoth brite Helped losen any contaments and also preped the metal... after that I re-cleaned until I had a Clean surface... |
Here is another twist for you if you have any sandblasted panels. PPG does not recomend and advises against metal treatment on sand blasted metal. Here is some info from the site, It's in the pdf below. Does this also mean that Picklex20 as well as other should not be used ? Does any one know why ? I was going to call the tech line on Monday to ask as I'm ready to spray some DP on my panels and I have used their DX520.
A long time ago, I used a rust cleaner that left a film, maybe Ospho, and I didn't like that at all and quit using it. I wouldn't use anything that leaves a film. |
I had not seen that before about not using acid treatment over sandblasted metal. It's difficult to see how it could do any harm. Doesn't make sense to me. Let us know what the tech line says if you would. One thing is that if the metal has been sandblasted clean, you don't really need any other metal treatment. I don't metal treat my sandblasted panels. I just epoxy it as soon as I can. Sometimes if I have a rusty panel, and I use a metal cleaner on it that can not clean all the rust off, I will lightly sandblast it to remove the last of the stubborn rust. Then epoxy it. |
I am surprised no one mentions this stuff, safestrustremover.com. It's slow and somewhat expensive but it does a pretty awesome job of removing light rust. For lightly pitted stuff, I have found just a spray bottle of it works well. Spray it, wait a bit, wipe or rinse it off, repeat. You need to soak deeper rust and you are want to get the big stuff first of course. But it gets into the pits, doesn't leave anything but metal and occasional carbon staining and really seems to work great for what I have used it for.
Is there some other drawback on this that I don't know about? I know it is really slow and doing a lot of rust eats up the product pretty quick but for getting that last bit of rust out of pits and things it really seems perfect.
1971 Firebird Formula 400 |
Well....I don't think it's really considered a film, since I think of a film as something that sits on top of the metal...something that has some thickness to it that can be scratched off fairly easily. I have seen that kind of film from another product, that looked and felt like a waxy film on the metal, that I was able to scratch off, and thought, "that's not good"
. Whereas, 520's zinc phospate is not like that. It's very thin and etches and bonds to the metal, so it's considered a metal treatment. And this treatment provides rust protection and excellent adhesion for the epoxy primer. |
When I rinesd with water I would get a flash rust effect. By that I mean a light orange surface rust from using water. When trying to clean with a chemical cleaner it would kind pick it up but it did not seem like it was getting everything. I never used the 520 because I was supposed to be able to just use the 579, neautrilize it, and then epoxy it... I just wasn't happy so I started using Acetone and red scotchbrite to neautrize it. no faliures so far and I have had parts that sat out side un covered for up to 1 year...
I've seen this too, I think the 579 will leave a coating if not washed with water, but the coating isn't suitable to paint over, it does somewhat help to keep it from rusting. Why don't you use the 520? It's a pretty quick step and inexpensive? |
#38
