Old 06-13-2008, 02:54 PM
Overkillphil's Avatar
Could also mount an electric motor inline on the driveshaft for the extra oomph, ultimately making a Pontiac 455 Hybrid! Then do donuts around Toyota Prius's!
Old 06-13-2008, 06:14 PM
COMP COMP is offline
Old 06-24-2008, 01:45 PM
6D6GOAT's Avatar
6D6GOAT 6D6GOAT is offline
Originally Posted by Half-Inch Stud View Post
A fella may want to use a DC motor to .....
Drive their TURBO!
just for fun, what kind of HP and torque requirements do you think you would need out of a DC motor to spool a turbo and keep it at like 14 pounds of boost?
im looking for a new project
Vic in SoCal. Follow me on Instagram- Cloud9orbust
66 GTO clone, 467 cubic inches of Turbocharged Multiport Fuel Injected fury twisting a TH400 into 3.90's wrapped in a 12 bolt posi.
My T56 Install
My Turbo Build
My Vortech Supercharger Build
Hyd Throw out bearing
Misc Build Pics
May the Karma Gods meet you half way....
Old 06-24-2008, 02:10 PM
triathlonx13's Avatar
I better order a good dimmer switch
Old 07-03-2008, 11:57 AM
livewire516 livewire516 is offline
i myself have thought about an electric motor at lower load to reduced lag on a large turbo. The much, simpler solution for quickly spooling a large turbo, is a little spray. Not suggesting you blow your motor, but if it's built for boost, it's can handle a little juice until you get some boost.
FTR this thread is off topic and I'm not helping----------
About the electric motor, I personally haven't ran the numbers but the initial investment of a motor and battery may exceed the benefits. And I sincerely hope you wanted to do this for economic reasons rather than ecological. If you thought this won't help the environment, I assure you it won't.
1968 Verdoro Green Firebird 350
Old 07-05-2008, 09:40 AM
shotgun shotgun is offline
PY Staff -Tech
Similar idea here,using a motor to boost an engine.
http://www.turbomagazine.com/insidet...ger/index.html
"resurfacing Pa highways 2 long black strips at a time"
78 Olds Cutlass Drag car PONTIAC powered with 440 (destroked 455), th400, 12bolt with spool 4.10z
Best to date [email protected] mph at 3250#
79 Grand Prix, will be new home for the 440
Goal 9.75z@135mph at 2900#
83 Malibu Wagon UUV Crate 350, Custom T5, 8.5 with Auburn posi 3.73z
Making it the Ultimate Utility Vehicle
Go, tow and show (not so much show, yet)
Old 07-06-2008, 01:16 PM
jnkgp jnkgp is offline
the original link is gone.
Old 07-09-2008, 08:29 AM
Half-Inch Stud's Avatar
I've put a starter-motor to an elec leaf blower & installed it in the 68 GTO...took it out because the relay would juice the motor over bumps, causing fuel spray all over the Q-JET.. Too scary when the throttle plates are closed//cruisin.
Got the assy (pretty much a 1/2hour bolt-on) sitting for another try after I clear-up some EXH issues, and get 1/4 mile times.
Such item was my "secret weapon" to go from 450HP to 650 HP on-demand, to reach 10.0 ET on that 12.90 combo below compression. Not dead yet, just time-compromized.
Old 07-09-2008, 09:47 AM
H.I.S., I got to get me some of that stuff you're smoking!
Old 07-28-2008, 09:53 PM
BVR421's Avatar
BVR421 BVR421 is offline
this makes at least more sense than putting little chivvy motors in Firebirds.
