Old 08-31-2008, 12:26 PM
70 bird's Avatar
70 bird 70 bird is offline
Originally Posted by 440GP69 View Post
How Much do these S400 Turbos run $ wise? Sounds like unlimited HP potential and I love the sound of turbo's spooling up to but the Install has freaked me out a little
I paid $585 for my 75mm s400 with a 1.32 exhaust housing. The install and tuning is alot of work, but I think its worth it.
Old 08-31-2008, 12:28 PM
440GP69's Avatar
440GP69 440GP69 is offline
HS you serious! 585$ LOL i thought the Procharger was a good deal, Turbo is where its at for Power
D.S.R.E. Your NW Pontiac Street/Strip Engine Builder, Specializing in Cylinder Head,Intake Manifold,and Exhaust Manifold Porting services and Building the Most Efficient stock rebuilds to Hi HP Pump Gas and Race Combinations for Pontiac,Buicks,Olds,FE Fords,385 Series and HP Gen 3 and 4 LS engines!
2006 silvy Z71 4X4,383 LS 600+hp NA
Shared Toy-66 Lemans 470cid by me 537hp 580tq-manifolds, 570hp 590tq-2"headers,custom cam,rpm intake, mild e-heads, Looks stock ;-}
Old 08-31-2008, 12:53 PM
6D6GOAT's Avatar
6D6GOAT 6D6GOAT is offline
here is the link...most of the guys get them here.
http://majesticturbodallas.com/specials1.html
Tom V. thanks for the info. if i cant live without boost in 1st then i will look at that. im hoping that i can get it to spool up a bit more in 1st with a little practice. on the positive side it does make launching it a bit easier. also, im just afraid that with 3.55's i ll never use 6th gear.
lemans411....kind of. but they would dump in a different place because i am using stock logs and have to clear steering linkages. also, i have seen those flanges on ebay. they do look like they would make things alot easier. i have seen them for 4 inch and 3.5 inch.
Vic in SoCal. Follow me on Instagram- Cloud9orbust
66 GTO clone, 467 cubic inches of Turbocharged Multiport Fuel Injected fury twisting a TH400 into 3.90's wrapped in a 12 bolt posi.
My T56 Install
My Turbo Build
My Vortech Supercharger Build
Hyd Throw out bearing
Misc Build Pics
May the Karma Gods meet you half way....
Old 08-31-2008, 01:06 PM
6D6GOAT's Avatar
Originally Posted by krisr View Post
Awesome! Would you be able to post some pics of the exhaust manifolds? That struck my curiosity centre when you said they almost worked just by swapping them around!
here is a shot of the style. i actually used the dark manifold just above the one pictured.
here is a shot of the manifold on the passenger side. as you can see it just catches the frame with about a 1/4 to go. i found that once i started grinding that i need to grind a little bit more so i could clear the flanges and be able to get the flanges on and off with out pulling the manifold..
here is a shot looking up and the outlet of the drivers side. directly above that in the pic is the steering column and rag joint. that line used to be the return fuel line for the fuel injection....it has since then been re routed for obvious reasons. the drivers side fit fine. the only grinding i had to do was to make room for the flanges. i still have some more grinding to do. my plan is to pull the motor shortly...grind some more to make it even easier to get them in and out and also make sure that nothing will rub as the motor torques. then i will weld in some metal to strengthen it up.
My T56 Install
My Turbo Build
Misc Build Pics
Old 08-31-2008, 02:02 PM
6D6GOAT's Avatar
Vic, Turbos need LOAD as your test runs prove to spool properly.
Take some gear out of the driveline. Drop the rear gear ratio by a bit
like 3.55 gears. The car's street manners will improve greatly and the
extra load on the engine/turbo will allow making boost in fist gear at lower rpm.
People with lots of gears in the trans rarely put enough load on the turbo to make it work properly unless the vehicle is a semi.
Tom Vaught
i just had an idea....I wonder what what kind of boost i could get if i simply took off from 2nd gear....
My T56 Install
My Turbo Build
Misc Build Pics
Old 08-31-2008, 03:19 PM
Tom Vaught's Avatar
Boost Engineer
Marty Palbykin ran 194 mph going from 1st gear to high gear (trans skipped second). So his engine basically was in high gear about 1300 ft. Try it, you might be surprised Vic.
Tom Vaught
Old 08-31-2008, 07:16 PM
krisr's Avatar
krisr krisr is offline
Ahhhhhhh yes I didn't even consider the clearance for the steering. Very neat idea though. Do those stainless flexy joints seem to have enough 'give' for engine torque? Mounting the turbo to the frame rail definately would put alot less stress on the exhaust manifolds and pipework associated. I see many aftermarket stainless manifolds on japanese cars cracking and breaking due to the weight of the turbo solely on them.
Old 08-31-2008, 07:19 PM
6D6GOAT's Avatar
......Do those stainless flexy joints seem to have enough 'give' for engine torque? .....
i hope so..i guess time will tell.
My T56 Install
My Turbo Build
Misc Build Pics
Old 09-01-2008, 02:14 AM
GOAT8U2's Avatar
GOAT8U2 GOAT8U2 is offline
Very cool, nice to see that the stock headers can be used.
I like the flex section to absorb the engine torque since the turbo is mounted on the frame.
If you ever want to get the car to leave with boost since you're a manual get a 2 step, it will build boost so you can cut some crazy 60ft's.
69 GTO Convertible, 4000lbs
462ci, 606tq/569hp - 93 oct @ 34 deg (207psi)
11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10", Rock Valley SS Tank, Dual 450s, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" & Borla Pro XS 3", Alum Rad & Dual Fans, 12:1 Box, UMI Arms & Viking Berz Fr + Rear CO Shocks, Hella UP5.0 Vac Pump, 12 Bolt, 3.73, 33 Spline
Old 09-01-2008, 09:51 AM
Donovan Donovan is offline
Or you could foot brake it, bring the rpms up against the brakes then take off. GN guys do that
Old 09-01-2008, 12:51 PM
Works great with an auto trans.
Won't work in this case, Vic's car has a 6-speed stick trans.
Old 09-01-2008, 01:11 PM
awww man
Umm line lock!
Old 09-01-2008, 02:14 PM
6D6GOAT's Avatar
lol, yep. that would be pretty hard to do.
My T56 Install
My Turbo Build
Misc Build Pics
Old 09-01-2008, 09:51 PM
opnwide's Avatar
opnwide opnwide is offline
I just checked out majestic turbo. He only lists a 1.34 A/R for the turbine, but I think you could get much more low end boost if you exchanged your ex housing for something around 1.0 or 0.9. If you're not approaching 1000 hp, then your losing a lot of low boost.
Its like choosing a 7000rpm cam, but shifting at 5500rpm. You never see the cam's real potential, and the high rpm cam is costing you low end torque. I think an exhaust housing change is a pretty simple event, if you can find the right one.
greg
1976 SE 455 twin turbo
austin, tx
Old 09-01-2008, 10:44 PM
6D6GOAT's Avatar
i agree. but i plan to run a 461-468 down the road. that should help a bit.
My T56 Install
My Turbo Build
Misc Build Pics
Old 09-01-2008, 11:27 PM
GOAT8U2's Avatar
While Majestic has great deals on BW turbo's I got my S474 T6 1.10 twin scroll housing from MikeTurbo for really cheap.
I'm only familiar with 2 step rev limiters done in the computer chip so you'll have to look into how to pull it off without an ECU etc. But the manual guys that got the rev limiter were really excited when they started leaving at 4500rpm and 8psi on their manual DSM's.
BTW, transbrakes really get the turbo spooling out of the hole.
Old 09-02-2008, 01:57 PM
opnwide's Avatar
15% more engine means you can come onto boost 15% earlier! That could be 500rpm.
greg
austin, tx
  #38
Old 09-02-2008, 11:38 PM
health services health services is offline
Will going to a full 5 inch exhaust allow for quicker spooling? If so will remote mounting of the oil filter give you enough room to do this?
  #39
Old 09-03-2008, 11:10 PM
6D6GOAT's Avatar
im sure the 5 inch down pipe is to reduce back pressure making it easier to spool... as for a 5 inch to fit even if you go with a remote filter... i would have to say that it would still be a real tight fit.
My T56 Install
My Turbo Build
Misc Build Pics
  #40
Old 09-03-2008, 11:15 PM
With your skills you should be able to notch the frame back there. If you do think about doing that I would try a test pipe first as the gains may not be even noticeable.
