I would do this first before I did anything else. Put a digital volt meter at the solenoid wire and the other to ground when the no start occurs.
If you have 12.5v with key in crank position, then it's definitely starter issues.
1970 Burgundy GTO hardtop. CVMS built 455 4sp. ![]() May the Torque be with you! John. |
You don't need a service manual to check out the starter. The (S) terminal on the starter solenoid should have power to it, when you turn the ignition switch all the way over to crank. That's a small terminal that should have a purple wire on it. If it has power, in crank position, the starter solenoid is bad. If no power to it, in crank position, hook up a temporary push button to start it, untill you get the wiring straightened out. |
