Non Pontiac Motors in Pontiacs includes factory 403,305,350 Chevy, Buick V6, Also Pontiac Motors in non-Pontiacs! |
finally done.
What oil pan did you use? Brackets? Fuel system? Harness? Drive by wire?
I am very curious as I am looking at doing the same thing to my 67 Lemans and think I am going to use a 6.0 just as you have done. I likely will be using a built 200-4r trans due to the gear ratios and has been proven fit and performance. http://www.drwtransmission.com/thm_200-4r.htm |
i used everything that came with the 2006 6.0, original oil pan, harness, PCM and electronic throttle. I used airtex e8200 external fuel pump and 02 and up corvette filter with regulator. I needed to grind off a few millimeters of the gear box so the power steering pulley could fit, aside from that it was an easy installation. I got my pcm tuned and eliminated all emission sensors but the o2 sensors. Its scary fast.
the 200-4r was my first option but i got the 4l60e with the engine so i decided to just everything.
