Old 10-17-2009, 08:17 AM
valkyrie9901's Avatar
valkyrie9901 valkyrie9901 is offline
I just use an old 2 lead trailer light.Always loose those small or break the small lights.......JB.
Old 10-17-2009, 11:11 AM
67cruiser 67cruiser is offline
Thanks silver, First thing i done already,Battery checked good and i have alt. checked, good also, this has been going on for quite some time, just trying to nip this thing. I usually just remove terminals every nite or if car sits for any length of time. Thanks for your input
Old 10-17-2009, 12:15 PM
Just had batt. and alt. checked, turned out good, just bought 12 volt lite, cool thing to have, i does lite up when positive term. is connected and neg. dissconnected with wire to neg,post and then to term. Drs. closed when checking, wondering my horns are not bolted in the front yet and wires dissconnected and just lying out, could this do it??
Old 10-17-2009, 01:46 PM
Pete,you where right on the money!! fuse on my meter was indeed blown, Radio shack informs me that my meter may not be big enough to handle a car batterys amps?? i have a 200m on meter and as small as 2 m, im doing some checking and learning, Ill keep everyone abreast on what i find.
Old 10-17-2009, 04:11 PM
ok, i started from the top of fuse box, and went down, the last fuse states stop and dome lite and there,s my trouble area, i pulled the fuse out and checked at batt. and no lite so now there,s the trouble area.
Old 10-18-2009, 04:18 PM
How much does anybody know about stop and dome lites??
Old 10-18-2009, 05:22 PM
LPete LPete is offline
I didn't spend much time looking, but here's a wiring diagram:
http://www.nikivee.com/documents/53.htm
On first glance, power goes from the fuse to the stoplight switch, and the fuse to the dome light. Try unhooking both of those and see what happens. You need to follow the circuit in the diagram and see what makes sense to disconnect.
Lee Peterson
"I didn't expect a kind of Spanish Inquisition...!"
'69 Cameo White RA III Judge, 4 speed, owned since 1977 -- my first car.
Old 10-18-2009, 07:36 PM
Pete, thanks for your help, getting a error on the website you posted!!
Old 10-18-2009, 07:39 PM
Hmm...
try http://www.nikivee.com/documents/53.html
Lee Peterson
Old 10-18-2009, 09:00 PM
Pete, got it!! copy that many thanks, not that i understand it but im going to try and figure it out!!
Old 10-21-2009, 10:21 PM
67bonnie455 67bonnie455 is offline
Default Check bulbs
I am glad the test light worked out for you. Easiest way I know to check em.
A bad bulb can be the culprit by the broken filament grounding to the base on the inside. Good luck.
Old 10-21-2009, 11:31 PM
An internally grounded lamp would blow the fuse, not cause a draw on the battery. It is a tricky thing to figure out, though.
Lee Peterson
