| Pontiac - Boost Turbo, supercharged, Nitrous, EFI & other Power Adders discussed here. |
i don't think anyone knows how much, and how many times i almost just quit.
i am glad i did not. thanks for al the nice comments guys!! |
Awesome! No one deserved it more then you, you stuck with it and now you got it. Congrats.
"Cobgarts"???
I don't think I'd wish "cobgarts" on my best friend...
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) ... or has a Pontiac born the same year as Jim Wangers? (1926}
Congrats Brad on the 8 second club, thats great.
Conrad 79 Trans AM 406 #12 heads Torker II intake Crower 60210 750 holley vac. sec. T400 3500 Stall 3:73:1 rear. ECMTTFMFers. IHTTFMFers.
Brad,
Great Job! Calvin |
thought i would share the specs on the car,
ia2 block, 477" 4"RA5 crank, 6.8 grp pro sereis rods, ross pistons(i designed the pistons and speced out the rotatig assembly) Butler E heads 317/230cfm that i reported and got 344/261cfm. victor intake also ported by me. comp cam my design- 260/[email protected] 288/[email protected] .440 lobe lift = .700net lift,(harlin sharp 1.65 rockers) 114lobe seperation installed at 109* 8.62:1 compression, c-16 fuel procharger F-2(my brackets) spining at 58,000 rpm @ 700rpm(80/48pulleys)=27#boost, Csu bonnet 1"spacer, and csu 850 carb w/dual needle and seat bowls- 76/80jets front brpv, no rear pv. hs airbleeds pluged, no jet extinsions. self built headers, 2.125" into 3.5" collectors. 3.5" pipes into #.5" dynomax bullet muflers. mallory unlight distributor,coil, digital box, msd superconducter wires, ngk #9 plugs gaped @ .020, 24.4* total timing from 4500rpm up, 38*below that. th400, ptc converter, pontiac 9.3" rear w/3.64:1 gears,(leave at 4300rpm) rear suspension leaf springs, slidelinks,some old swap meet shocks, 12"rim w/ 29.5"/11.5" mt slicks. front suspension, stock setup w/ moroso sprins and summit adjustable shocks set at 60/40 ratio. raceweight is 3590# fuel system- 5galon cel,-12 &-10 lines, 500 & 275 manafuel pumps, 2 -10 lines megeing in to a -12line foward, 13202regulator, (set at 9#) a -12 return line, -8 lines to the carb. i think that is about it, maybe this info can help someone else out! ![]() brad. |
Way to keep at it, congrats. You must be proud.
Jim
65 Catalina sedan. Allen Thomas Performance 495. KRE Heads at 310cfm ported by SD Performance, ProSystems Dominator carb on ported Victor intake, P-Dude custom grind hydraulic roller, MSD ignition, 3.50 Moser/Ford rear. F-Glass front bumper by son Rob, rear by the old man and joint effort for trunk lid. 3950# w/driver. Best of 9.5761/139 on 175 shot, 6.01 /114 in 1/8. |
Great job, Brad, been along time coming, and a hard and expensive road to hit that eluscive 8 second goal! but you finally got there!
Great job man. It takes superior tenacity to achieve that level of performance. I can remember racing at Bristol once when I would of sold my soul to the devil for 1 more 10th.
79 Pontiac Trans Am |
Good job Brad...thought i was gonna have to loan you my $40 Q-jet to get you over the hump! hehehe
Got Marty's LeMans to a 12.98 last nite! But the dang thing is pukin off the line. it was way lean in the primary, its got 37shooters in it, i think he may have a plug bad. hard to tell, it may need the pump cams adjusted or more shooter in rear. Ive never had to run that much shooter in my holley. I dont think its a rich shooter prob. Just have to keep screwin with it .....q-jet right around the corner!
1962 Catalina 4100lbs trw 455, iron d-ports,perf RPM, 800holley, 9'' tires,([email protected])1.578 60' Oct 2010!! ![]() ![]() ![]()
new thread taken care of.
congrats Marty. |
Nice job Brad, another super fast Pontiac. Must be a great feeling. I hate it whenever I surpass a goal. It just means I have to work harder. You done good. MArk L
i don't think that i have to work much harder,
i just need to give the engine and blower what it wants. it is ready to go, i put .6* more timing in it and raised the retard to 4600rpm to give it a little more bottom end. now i just need $75.00 for race gas, $35.00 for gas money, and a $25.00 entry fee. all of wich i won't have till next month, if anyone has some extra $'s i would be more than happy to spend it for them ![]() again thanks for all the positve coments guys. brad |
