Old 09-06-2009, 10:37 AM
grandville455's Avatar
grandville455 grandville455 is offline
Yea we have tried two different dist and two different modules, and Like Tom Says I can pull it out of the Block and it sparks awesome!. I have been finding alot on moparts.com about this and it seems this quite common with the mopars!..either the damn bulk heads or wiring somewhere. When I go back this time I will have a schematic and some good info for tracing the circuits now. Thanks Tom for the site!
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,[email protected]@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected]
M/T 275/60 ET SS Drag Radial
2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's
Old 09-06-2009, 11:33 AM
jdw_poncho's Avatar
jdw_poncho jdw_poncho is offline
To test for a bad ground run a new wire from the battery ground to the dist while its out and spin again. Just strip back and shove under the cap so it will hold it while you spin. If the spark goes away I'm guessing the pick up is shorted to the dist body. Did you say you tried a new pickup?
Old 09-06-2009, 02:28 PM
what do u mean have the cap hold it? hold it against the steel body of the dist? yes this is a brand new dist, old one does the samething as far as the no spark thing..
Darby
Old 09-06-2009, 07:20 PM
jdw_poncho's Avatar
I was thinking this would be a easy way to hold a ground wire so you could hold the dist and spin it at the same time to check for spark. Stick it between the cap and the body of the dist. My guess is if you ground the dist your spark will go away. I was thinking just use a seperate wire from the dist to the battery - post so you could double check that it acts the same as if its mounted in the engine.
You said you have a blue spark at the coil wire. Does that mean you have the wire off the dist cap? If so, have you checked it by leaving it on the cap and using one of the spark plug wires instead?
Old 09-06-2009, 08:26 PM
Yes I can try that to mimic what the block does.. Yes I have tried it at the plug no spark.. same as at the coil.. sparks once then nothing while cranking.
Darby
Old 09-07-2009, 04:16 AM
This is getting back to the 'start' and 'run' position theory but...You know it sparks outside of the block with the switch in 'On' but what about 'Start'?
Just for kicks, have you tried taking it out of the block and spinning it while someone holds the key in 'Start'?
I guess you'll have to re-time it afterwards but seems like you're running short on ideas.
Old 09-07-2009, 08:19 AM
Disconnect the brown wire(starter sol) at the starter relay would keep it from cranking while in the crank position.
Old 09-07-2009, 09:28 AM
No I have not tried that Greg , But I will tomorrow. Tom Are u saying pull that wire off so it doesn't turn motor over, but i can still check for voltage while in the start position on key?
Darby
Old 09-07-2009, 10:05 AM
sleepy's Avatar
sleepy sleepy is offline
Maybe this will help. As you can see there is TWO power circuits for the ignition from the key. one in the run position and one for start. I think the wire or connections on the start circuit is the problem.
Why is he not suspended?
Old 09-07-2009, 10:13 AM
Yea Definatley thinking something is fubar somewhere!
Darby
Old 09-07-2009, 01:02 PM
Yes it will keep from cranking but should send the higher voltage from the ignition switch to the coil pos side.
Old 09-08-2009, 12:40 AM
Hey Tom go over to the moparts site and look at what i found tonight!
http://board.moparts.org/ubbthreads/...=0#Post5463763
Darby
Old 09-08-2009, 05:31 AM
Good going. Just a matter of time now. I hate following previous owners' "work"...lol
By the way, I've had Mopar trucks for years and that site has been a lifesaver for me several times. Usually find the info on the site without having to ask anything.
Old 09-08-2009, 07:21 AM
Greg this has been a nightmare for my brother! This car is beautiful, but the mechanical **** we have found wrong etc is just unbelievable! used timing chain in it, worn dist, and its gear for oil pump, shot water pump put back on.. and Now this mickey mouse wiring hack job!
Name:	72 Challenger.jpg
Darby
Old 09-08-2009, 07:44 AM
Sounds like he just needs to go through the whole thing like a resto. It looks so good that that ought to be good incentive to do the work... It is a beauty.
Old 09-08-2009, 08:09 AM
Yea this guy did nice work on the body ,but the rest of the crap we have found leaves something to be desired!.Why u wouldn't put in a new harness is beyond us! cheap way out!!.The worse part is it was a cash deal with the guy telling him it just needed some tuning and a water pump!! uh huh!
Darby
Old 09-08-2009, 09:41 AM
Ron Landis's Avatar
Question Question...
was this initially a points type set-up? If so....it should require a separate feed wire. "R" terminal and "S" terminal both need to be hot when the key is on. Just a thought. Ron
  #38
Old 09-08-2009, 10:46 AM
I don't think so as he also has a 72 charger same setup. now the 69 motor was originally a dual point thing, but the 72 year car had the electronic, so the dist was changed
Darby
  #39
Old 09-08-2009, 07:32 PM
It originally a very good ECU system dependable for very hi rpm's. Other than ballast resistor(which all Mopar guys keep a spare) the system works great That said I have a aftermarket dual point Mallory system in my '72 'Cuda (it came with it). Like I said before Moparts is to mopar guys as PY is to Pontiac.
  #40
Old 09-08-2009, 08:40 PM
blue goats's Avatar
blue goats blue goats is offline
When you change over to electronic ignition the factory tach in the rally gauge set up won't work any more for some reason. Happens every time with mine.
