Old 01-17-2010, 09:08 PM
John Langer's Avatar
John Langer John Langer is offline
When you put a rack on a first gen f-body, you put it in front of the spindals, you swap the steering arm from side to side to do this. You then need to put a bar or something up there to mount the thing. If lil baby maker puts a bar in front of the motor, he will have full access to the oil pan and can put a better pan in the car. Better pan = more power and he deffinately needs some of that.
Old 01-17-2010, 09:21 PM
quick67bird's Avatar
quick67bird quick67bird is offline
John,
Do you have any pictures of how you mounted your Rack and the crash bar you are talking about.
Robert
67 Firebird 467 cubic inches 7.71 @ 92 in the 1/8 and 11.69 @ 115 in the 1/4.
Old 01-17-2010, 10:25 PM
There are plenty pictures of my car on the rear bumper out there. It is quite visible in them. I have been in Florida for the last few weeks "working" so I can't really forward anything.
Old 01-17-2010, 10:28 PM
Thanks John, I will find a pic of it up on the bumper and check out your Rack. I want to convert my car to a rack and doing research before I start.
Robert
Old 01-18-2010, 10:13 AM
bigchief468's Avatar
bigchief468 bigchief468 is offline
Default C/FX NSS
Jack, I will be cutting my cross member next year this time. I want easier access with the next motor and bigger headers. I was going to cut the back of the cross member, near the frame rail, and the top of the cross member for the headers. I did not think I would have to cut the whole cross member out to get the 2 1/4" headers in. What am I missing or what other reason are you taking the cross member out?
505 KRE HP head 2x4 HP 1000s
60' 1.33, 5.78 @ 120.88MPH in 1/8
[email protected] in 1/4
Old 01-18-2010, 12:13 PM
Tom Vaught's Avatar
Boost Engineer
Originally Posted by John Langer View Post
The front x member was completely removed and a piece of moly tube was put back in its place to mount the rack. There is an integrated "crash bar" mounted on this bar that triangulates back to the lower control arm mounting point for reinforcement. The "crash bar" is the lowest point on the front of my car and what hits the gound and absorbs the impact.
I figured as much.
You install a very strong chrome moly tube cross-member/ "Crash Bar" (which you said yourself takes all of the impact) that you also use to mount the rack for the steering.
Sounds to me that Jack would need to do EXACTLY the same deal for your example to hold water. Otherwise it is apples to oranges.
If you are not going to change to a Rack/ "Crash Bar" , Jack, install the the removable piece on the existing frame with the mid mount, the front mount, and the "J-bars".
Tom Vaught
Old 01-18-2010, 02:32 PM
Dave Polichena's Avatar
Dave Polichena Dave Polichena is offline
Arrow
Here is how I did mine before putting the rack in. Like John, I have a chromemoly tube in the front to mount the rack. For the minimal weight savings it gives me piece of mind having that center in there. I will say though, everytime I have had to remove it over the years, there is no binding when removing the bolts.
Dave Polichena
Old 01-18-2010, 03:43 PM
Brian Baker's Avatar
I figured as much.
Tom Vaught
So then, John's block does not act as a stressed member of the chassis with the addition of this "crash bar".
Old 01-18-2010, 06:25 PM
Tom Vaught's Avatar
Boost Engineer
That is my point, it does act like a stressed member to keep the frame rails in position.
Any rack mount that is also acting like a "crash bar" will keep the frame rails in position when used with a front and mid plate. Does Diaper Boy have a rack or crash bar presently in his car or just conventional steering box?
You need to look at the whole picture vs one part.
I would say that if Jack has or puts a rack/ crashbar into his frame system he will be ok, without the rack/ crash bar I would install the removable support like Dave P did, expecially with normal steering.
Tom Vaught
Old 01-18-2010, 07:18 PM
My block is not a stress point. The motor and mid plate could possible be defined as one with the torsional load of the crash bar hitting the ground but it is highly unlikely. The 2 plates basically prevent a bending moment if the moly pipe/crash bar fail. The only load the block would see would be the efects of gravity on the 5 bolts in the trans and the 4 bolts in the engine plate. Pure shear. But since the engine can't move (in theory), again there is no load on the engine. Now if the engine pan or trans pan smacked the ground, all bets are off.
Old 01-18-2010, 07:20 PM
Polar-Pontiac's Avatar
Polar-Pontiac Polar-Pontiac is offline
Robert
Some pic of when I did my car.I put a TRZ rack in works well.
Old 01-18-2010, 07:52 PM
Tom Vaught's Avatar
Boost Engineer
Agree, In your case the engine and trans are going along for the ride. With a supported chassis that doesn't put a load into the front of the block how can it see a stress?
Your crash bar must be pretty beat up with all of the bumper rides you seem to take. What did it cost you to fix the chassis the last time you dropped it??
Tom Vaught
Old 01-18-2010, 09:28 PM
Last time I dropped it was 2008. It has cost on average of 10k each time it has happened.
Old 01-20-2010, 05:36 AM
jts ocd-stang's Avatar
jts ocd-stang jts ocd-stang is offline
Lightbulb Nice Job!!!
IMO,LIL JACK,you are paying someone to do the conversion for you???? WOW I guess only Indiana Hillbillies do there own work,everything but machining engine parts/components?Must be nice to be rich LIL Jack
jts
Originally Posted by LiL Jack View Post
One more!
And that is an All Pontiac front plate in the car.
Old 01-20-2010, 11:05 AM
Gach's Avatar
Gach Gach is offline
Are you kidding Jack wips his butt with $100.00 bills
Old 01-20-2010, 10:11 PM
Fish's Avatar
Fish Fish is offline
Send a message via AIM to Fish
Jack does not wipe his butt.... His "laborers" do.
wehadababyitsaboy.
YouTube videos.
Old 01-20-2010, 11:27 PM
60man's Avatar
60man 60man is offline
You still work for Jack Fish ????
ECM member.
MANDRA
  #38
Old 01-21-2010, 08:22 AM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
I don't know how to weld, therefore I pay.
Fish should be on the payroll.
First Pontiac powered street car in the 7's
[email protected]. 3460#s
  #39
Old 01-21-2010, 10:40 AM
Fish's Avatar
<---Will work for Ravens and O's tickets...
I still do not get how you never learned how to weld!
wehadababyitsaboy.
YouTube videos.
  #40
Old 01-21-2010, 10:42 AM
Fish's Avatar
No, I got enough asses to wipe here at home.
wehadababyitsaboy.
YouTube videos.
