Old 10-22-2010, 11:23 AM
Those numbers at just FOUR lbs boost should clue you in on the potential. IMO there is more than enough under hood to go well below 9's ON pump gas. Actually glad he plans to turn it up a bit at a time. Good plan.
There should be at LEAST 1600 hp at 15 psi on a conservative tune if the turbo can supply enough air. A whole bunch more if intercooled.
Yeah he's going to have his work cut out to get that power to the pavement.
Old 10-22-2010, 12:07 PM
badassgoat's Avatar
badassgoat badassgoat is offline
Rob, here are a couple of shots I took with the digital camera....
ID:	221909   Click image for larger version
ID:	221910   Click image for larger version
ID:	221911   Click image for larger version
ID:	221912   Click image for larger version
69 'Blackbird'
535 CID IA II SD Wide Port E-head Pro Systems Dominator
Old 10-22-2010, 12:12 PM
bankbook's Avatar
bankbook bankbook is offline
Thanks Paul for getting my best "side".
DOC'S TA
Turbo 535, CV 1 heads.
Built by Cerralli Competition Engines
Tenth Anniversary (Van Nuys) restored.
Tenth Anniversary Barn Find (Norwood)
Both 4 speeds!
Old 10-22-2010, 12:22 PM
Wareagle's Avatar
Wareagle Wareagle is offline
Smile
Yes - one Kick-Butt T/A -Pontiac power !!!! .
Old 10-22-2010, 01:55 PM
RUDOLFSSON's Avatar
RUDOLFSSON RUDOLFSSON is offline
Congrats Doc!
That's awesome for first outing at this boost level. You have potential to go easy 8's with your combo at some nice conservative boost levels and even on pump gas. How did the tune feel like? What a/f readings did you get through the run?
Sounds and looks great from the video, looks like you had a rich mixture in it, smart move.
Kris
Old 10-22-2010, 02:57 PM
cgeise's Avatar
cgeise cgeise is offline
better send in the time slip -- or it dont count BWAAAAAAAAAA - good job are you running a boost controller ??
Old 10-22-2010, 03:13 PM
bankbook's Avatar
Ran it rich and then started jetting it. Went from 11.5 through 13.0.
cgeise- Running an AMS-1000. Had it programmed to run off the gate only during the license runs.
DOC'S TA
Both 4 speeds!
Old 10-22-2010, 03:14 PM
Polar-Pontiac's Avatar
Polar-Pontiac Polar-Pontiac is offline
Smile
I am sure he will when it counts.....Rules are Rules.....Did you send your time slip yet...
Old 10-22-2010, 03:21 PM
cgeise's Avatar
be safe - -remember those turbo cars like it a little rich
Old 10-22-2010, 03:22 PM
bankbook's Avatar
Mark,
Watched that video in your sig again. Love the way your car launches! Music is perfect for it as well.
Rich is always better I agree.
DOC'S TA
Both 4 speeds!
Old 10-22-2010, 03:23 PM
cgeise's Avatar
Nope - he can bite me - I sit here with on my desk and look at it almost every day , just because I can
Old 10-22-2010, 05:47 PM
LOL that's funny ..
Old 10-22-2010, 06:21 PM
cfmcnc cfmcnc is offline
Doc ,your off to a good start,call me ,we have a track rental on Fri, Oct 29, at island ,track will be sprayed half way .Bill C.
Checkered Flag Machine & Ceralli Competition Engines
Racing engines and induction development
http://www.checkeredflagmachine.net/
Old 10-22-2010, 10:13 PM
Tom Vaught's Avatar
Boost Engineer
There should be at LEAST 1600 hp at 15 psi on a conservative tune IF THE TURBO CAN SUPPLY ENOUGH AIR. A whole bunch more if intercooled.
You don't need much "boost" on the gage when you have a 106mm turbo moving the air inside the engine. John Welter runs a 106mm turbo and has gone 6.80s. You really think it will be an issue to break into the 8s with that turbo on the car, LOL (:>)
Tom Vaught
Old 10-22-2010, 10:38 PM
Ron H's Avatar
Ron H Ron H is offline
What are you thinking for suspension changes with the mini tub?
Cal Tracs
4 link
Ladder bar
68 Firebird
Are you running with the wind or breaking it?
Old 10-22-2010, 10:47 PM
I think there tons of power there to run 8's but is the car up to the task.I mean safety wise..cars that heavy need a special cage I think its 25.3 tag.A bonsai run into 8's would be great for bragging rights but not very practical.Then there stopping all that weight at 160 mph plus..just something to think about.
Old 10-22-2010, 11:41 PM
Tom Vaught
Tom I couldnt remember what turbo.(Thats why I stated IF the turbo can supply the air) I do know with his CV1 heads if he sees 15 psi on the gage there will be a LOT of pounds of air flow. I've forgot his flow numbers but thinkin around 400+ cfm. Conservative guesstimate 1600+hp at @15 psi on the boost gage. Heck a 270 cfm head at 15 psi can support 1000+ with the right turbo and intercooled.
  #38
Old 10-22-2010, 11:42 PM
Torment's Avatar
Torment Torment is offline
How heavy is this car? I've seen lots of 2nd gens deep in the 8's and in the 7's as well. More tire would be nice, but setup properly a small tire caltrac car can put down some serious hp with a drag radial... Lots of guys doing it in the 7's and 8's - some faster yet! Best of luck with it!
The secret to happiness is not getting what you want but rather, wanting what you have.
  #39
Old 10-22-2010, 11:52 PM
Yes there is but most of those cars are built for that purpose.They are not 2nd gen firebird with cal-trac and a roll cage running low 8's or 7's.Those cars come from shops like DMC and other like it. Lets not kid our self it's not that easy ..
  #40
Old 10-23-2010, 12:22 AM
badassgoat's Avatar
Got me seriously thinking about a turbo doc...
69 'Blackbird'
