Old 11-19-2010, 01:54 PM
grandville455's Avatar
grandville455 grandville455 is offline
Originally Posted by mchell View Post
done with installation........lashed lifters to .015 (the vmax lifters lash like solids)........not obnoxious at all....
....idles better.....vacuum signal to carb much better...
4" more vacuum....pulls HARD on top end and has loads of torque on the bottom end.....
two thumbs up for the Rhoads vmax lifters..
Didn't i try to get you to run those years ago ...
Good job man!.. when u hitting the track!
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,[email protected]@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected]
M/T 275/60 ET SS Drag Radial
2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's
Old 11-19-2010, 06:00 PM
Curious mike did u do cranking comp test before this? curious to see what it is now with just the lifters added..
Darby
Old 11-19-2010, 06:53 PM
mchell's Avatar
mchell mchell is offline
yeah, did some cranking comp tests prior to install......will have to run em again to see...
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile
Old 11-19-2010, 07:31 PM
Cool post the before and after. be curious to see what they are
Sound's like she is a beast now!
Darby
Old 11-19-2010, 08:20 PM
DAVE RIBEIRO DAVE RIBEIRO is offline
Can you guys tell me the basic difference between regular Rhoads lifters & V-max ... I have been running regular Rhoads for 4-5 years
with no-problems .. I do preload at about 1/8'' down ... The car is a NHRA 350 ci. Pontiac Stocker, with a 364/364 lift Hyd. cam ... Use to run real fast, but have lost a couple of tenths in the last two years... Looking to make some changes ? It's a 77 Formula Firebird , that weighs 3800 lbs. w/driver & run's 12.20's at 109 MPH, 1.60 (60') t-200 metric , with 9" Hoosiers & Q-jet, stock manifold,6X heads (stock) 92 cc....
thanks in advance for any idea's .......... Dave...1033/stock(RV-455)
Old 11-19-2010, 08:41 PM
mchell's Avatar
the vmax's are pretty flexible meaning you can adjust lash for the desired bleed level......they really act like solid lifter......
from Rhoads:
"They increase low-end torque and engine vacuum up to 50% more than Orginal Rhoads Lifters...and they rev higher too. This makes them the best choice for hot street, performance marine and all racing applications"
