500 series BME's at the same length, 6.700" are about 40g lighter then the 396 series from the comparisons I've had over the past few weeks.
Calvin Hill Hill Performance 708-250-7420 |
40 gm's, that huge. Good info
Joe |
I was leaning on using a BM rod next season in a circle track application. I called and talked to Bill to pick his thoughts. He said they had mixed results. He did not recommend a aluminum rod in that type of racing where you go wide open, then let off repeatedly. In a drag race app i have over 100 passes +dyno time on a set of 426 series rods at 1000+ hp. This series rod can take much more hp than this. Eric, what series rod do you use? |
Just curious how much do these rods weigh?
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119 |
BME rods (396s) in my hemi have around 200 runs on them. A "run" is up to 20 seconds long in mini-rod pulling. I see them going "forever", with only 3.75" stroke, no more than 9,000 RPM, and probably a little shy of 1,000 HP.
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) ... or has a Pontiac born the same year as Jim Wangers? (1926}
