| The Body Shop TECH General questions that don't fit in any other forum |
They prepped the floor with a diamond grinder, no primer, then applied the epoxy. They allowed it to cure to a certain point before adding grey/white/black flakes, then coated with resin. True on the 'not cheap', and I shopped for weeks with quotes all over the place. As an example, for a 26x24 slab, it ranged from $2500 up to a breathtaking $16k. I ended up paying $4k, which was in 2022 money. Especially considering the amount of prep work there was. I beat the heck out of it, and it's taking the punishment, so am satisfied and not regretting the cost. One thing I will point out though, with the flake, if I drop a screw/bolt/nut/washer, it can take a half-hour to find it, even if it's right at my feet! Heheh! Most of the time if I put my cheek to the floor and look at floor level, I can find it, but if you're planning on doing a lot of work in there, I would suggest a solid color or at least something that provides some contrast. EDIT: Make sure you give it ample time to cure, and then wait another few days! .
