Old 03-24-2011, 05:45 PM
Tom Vaught's Avatar
Boost Engineer
You are correct Mike, for a track car the dual breather lines might work better in the "push" (high crankcase pressure/ low vacuum) mode.
Tom Vaught
Old 03-24-2011, 06:46 PM
moontower69's Avatar
moontower69 moontower69 is offline
Thanks Tom, that totally answered my question -- for a totally street driver w/ tripower, i only need stock pcv from valley to intake and ONE valve cover breather, 2 is not always better in my case. Sweet, previous owner had NO breathers but just pcv and didn't understand idea of a "loop" of air....I want/need this rebuild to last, I'm stoked.
1974 Lemans Sportecoupe GT (daily driver)
.030 over 354, #47 heads (84cc), Lunati voodoo 700 camshaft (207/213 @ .050), logs, 2.5 duals, X-pipe and Dynomax super turbo mufflers, 3.08 rear
Old 03-24-2011, 07:06 PM
goatman-68's Avatar
goatman-68 goatman-68 is offline
Tom Vaught
I've always been a fan of two breathers, pcv and a puke can in the past on my street car. I had the old Hastings double moly filled 1/16-1/16-1/8 ring's on my first motor and at 7000 it had a little crankcase pressure. On my new build I have a single plazma moly pack, but am still going to run the dual breather, puke can and pcv.........
Frame off (resto mod) 68 GTO - 406, 0-deck, E-Head home port 87cc, TRW L2279F30, Comp. flat solid .577/.577 - 248/[email protected] 110LS. 700R4, Precision Industries 3 disc 10" lockup 3500rpm, Moser 9" 4.11, Detroit Locker.
Old 03-25-2011, 07:51 AM
HWYSTR455's Avatar
Anyone know where a flow chart or values/specs for PCV valves can be found?
Old 03-07-2024, 01:01 PM
Tim Corcoran's Avatar
If you have the hood clearance you can put a spacer between the carb and the manifold and drill and tap the spacer in the back or front. this would give you pretty good distribution.
Tim Corcoran
The Following 2 Users Say Thank You to Tim Corcoran For This Useful Post:
Old 03-07-2024, 01:05 PM
For a drag car with no exhaust a header evac system works pretty good if installed correctly. Not as good as a vacuum pump but second best.
Tim Corcoran
Old 03-09-2024, 10:53 PM
Tom Vaught's Avatar
Boost Engineer
I posted a spec sheet for all of the Ford PCV Valves some years ago.
They all were the Shuttle/ Backfire Spring design.
2.5 cfm to .70 cfm for all of the Ford stuff.
Crankcase does not car whose name is on the part.
A company does sell a "bend-over - got your money from your wallet
set-up. Wagner maybe but not sure Over $100
TV
