I have this posi in one of my 69 GTO's and LOVE it on the street. The other 69 GTO is a full spool and even though I have and do drive it on the street you definitely make wider turns and do lots of backing up and trying it again...
1969 GTO, 5.77 @ 121 1/8th mile 3450 lbs...535 with Junk dinosaur Eheads Faster on nitrous… |
Andrew, As everyone has said a spool is not very street friendly. Tears up tires hard to make tight turns in parking lots and it is not funn in the rain. I have a Detroit Tru trac I took out of my car for sale. It is a 3 series but I believe you can buy spacer rings that would probably be ok for a mild race mainly street car. I will cut you a screaming deal if you are interested and I could probab ly get a good shipping rate thru work. Email me if you are.
I'd stay away from the spacer too, if you're running slicks. Seen lots of ring gear bolts broken with those things. 40 years ago I was running a 69 Camaro with a 4 speed and used ring gear spacers in my 12 bolt. I broke at least 3 sets of ring gear bolts, from 3 differant manufactures. Switched to a 4 series carrier, problem solved.
They do sell thicker ring gears for 12 bolts so that you don't need a spacer behind it. Don't know if every ratio is available,but worth looking into.
I just looked for a thick ring gear for my 8.5 (Which they DON'T make!), but saw plenty on the market for 12 bolts.
‘63 LeMans- ‘69 400 w/ original transaxle. 2.69 gears. ‘55 Catalina ‘62 Mercury Meteor-all original, bought new by my grandfather 71' GTO -original 400/4-speed/3.23 posi 13.95 @ 102.1 on street tires @ 4055lbs.-now my sons ride |
Is it for 33 spline? if so let me know, I will call Detroit tommorow and ask about the spacers. My car is stick right now. The Truetrac is different from a locker, so it won't be a problem in a stick car on turns? (I have read that lockers and stick cars do not go well together from my brother who is a UMTR guy.
The Educated Fool |
Another issue when running a spool on the street: If you do any highway driving where there are grooves/ruts in the asphault from big trucks be CAREFULL because the spool will cause unexpected lane changes! You will feel it pushing you.
Parking is always a concern because you are binding the axles. JD
Good luck to the new owner of the Ventura II! Sold the car after 13+ years. Look for it on the Hot Rod Power Tour in the future as it's currently being re-configured as a Pro-Touring ride!
Dont cheap out, get the Eaton.
If you break that, need a stronger rear end to begin with. Know 2 guys with Brute Strengh's that run mid 9's for yrs. I have one with 4.11.s Really want 3.55's in my current 70% street/25 strip car. My racing buddy since the 70's(also runs 9's), and builds BIG power stuff for $ guys says DONT spacer it if your gon'a hook. Make room for taller tires.
Car still have sway bars? You could set it up like mine and not need a posi at all.
Now that I have done more reading everything I see about the true trac in a street/strip environment is negative! it has both front and rear but they will be coming off and I will be putting in anti roll when the rear one comes off. Please explain though; you have piqued my interest.
The Educated Fool |
Andrew, its an Eaton type posi.
Supposed to have stronger case and guts. Made by Moroso. How knows, maybe just a reboxed Eaton??? Never seen one apart.
I have read guys saying that the clutch packs on the brute strength are so tight they chatter going around turns like a locker.
The Educated Fool |
They also make a thin gear 12 bolt 3 series to use on a 4 series posi/spool. Had to get one for the 3.73 and the spool in the Camaro/IA project 12 bolt.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
Mine does not chatter going around corners. The only way I'm aware of that will cause that is not using the correct oil in the differential.
Is there much difference in driving with a detroit locker on the street and a spool??
My '60 has a 9" with a locker...and the '57 I'm building will be using the original 57-64 diff with 35 spline and a spool. The '60 has been street driven for over 10 years...just fitted power steer this year. Have never driven with a spool. |
We ran Brute Strength stuff in a 64 GTO in 1971 in the low 11s. Never had an issue
once we installed the GM "service pack" axles to go with the rear. Always liked that rear when it was set up properly. Had a few friends wreck their late 60s Mustangs when they tried to run spools and slicks on the street. A Ford 9" allows you to have a pig set up for a STREET gear/ Posi and a RACE pig set up with a spool and the right Drag Gears for your track (say an 1/8th mile deal). Tom Vaught ps Spending money several times to "save" money the first time is primarily due to inexperience. Some times you just have to bite the bullet and buy the good stuff initially.
. My buddy with a fox body has been doing everything twice because a) he is in a rush and b) he is so cheap because well he heas no money really.I am the guy who always preaches about doing it right the first time, and I always do (everything I have put on my car so far is QUALITY) but before I put the money down I always rethink it about 50 times, before my wallet gets much lighter
The Educated Fool |
#38
The average inexperienced guy is different from the "Guy who is in a Rush" or the "Cheap Guy". Sometimes you get both (like your buddy) in one package. The difference is: over time the inexperienced guy will learn and will make sound decisions. The "Guy who is in a Rush" or the "Cheap Guy" will not change over time. Tom Vaught
#39
The Educated Fool |
#40
IF you're admitting to driving it in the rain stop right there, get a posi.
If you can guarantee no wet weather driving run a spool. |
