If your backing plate is the same thickness in the bolt area it certainly will... |
I have their axles w/ taper bearings- they do work with the factory discs BUT the pilot will not locate the wheel as it barely sticks out of the rotor. So it makes the lugnuts needed to locate it. Problem is snowflakes(or turbos) have a .700 lugnut and around a .740 hole so enough to move the wheel around on the lugnuts and make it not centered.
Factory disc axle pilots are darned near .750 for that reason as the rotor is thicker than a drum brake hat. Moser also tells you they should be lugcentric.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
Just to clear up some confusion on what 73-75 10 bolts axles used bolt in axles.
If the axle is in a GMC Sprint, A-body Wagon, or a Chevy Elcamino it is probably not an 8.5, most versions of those bodies came with BOP 8.875" axles, a shorter version of the Big car axles. And again most of those are C-clip Axles. My 73 4-speed Lemans Wagon came with a Bolt in axle 3.42 Posi 8.875" axle. I do not know what other aplications they were used in, also my car is a fairly early 73 build of 2nd week of October 1972. Later in 76 or 77 all those cars came with revised and lightened 8.75 axles, and all of those are C-clip axles. I have also never seen a 8.5 axle with bolt in axle retainers, does not mean they didn't make them. Most non-station wagon or B-body people do not seem to know about the large car axles.
Jeff R 60 Jaguar Mark 2, 3.8L Automatic 67 Sprint Firebird 230 OHC-6 4-Speed A/C 1971 Fiat 130 Coupe 3.2L SOHC V6, ZF 5-speed 78 Catlina Safari, Pontiac 400 powered 77 Astre Formula, 215 Buick V-8 T-5 73 Lemans Safari, 400 4bbl 4-speed 71 Catalina Enforcer, 455 4bbl 05 Dodge Magnum 3.5L SOHC V6 06 Mallet Solstice #024 LS2, Now with a Tremec 6060 6-speed! 2012 F-150 Echo Boost (My local Ford Dealer SUX!!!) 2020 Dodge Charger Scat pack (recovered) |
I have 2 8.5" rearends with bolt-in axles in my 73-75 a-body cars. You can see in the factory service manuals that the B(Buick) and O(Olds) a-body rearends are the bolt-in (non-c-clip) axles. And sometimes the B and O rearends were put in Pontiacs. My 73 GTO and 75 Lemans have the Buick rearends in them, with 3.23 and 2.56 gears respectively. Other Pontiac a-bodys came with Chevrolet 8.5" rearends, like my 73 Grand Am with a 3.08 posi.
Steve F. |
missed this one, looks like original posi carrier topic went a couple different directions. guess I'm as much to blame as anyone.
Cliff, thanks for the you tube link. Very impressive! will send you a PM. Skip, If Moser would just source some axle blanks that were thick enough, they could machine 'em & make everyone proper fitting disc axles. It irks me too, we can't buy a HD axle with the .740 pilots. Have a local friend, we went through this on his rearend build with 30 spline axles for his 79 T/A. The Moser pilots were right under .500 thick. He works in the oil patch & picked up some 3" diam steel washers that were 1/4" thick. He had a local job shop, center & weld the washers on the ends of the pilots of his new Mosers. His machine shop buddy, then slightly turned down the washer & put a small bevel on it in his lathe. Not exactly what I'd like to see, I've seen things rigged worse. That said, this actually worked & looked decent. his snowflakes are centered. On the other tangent... there are 4 different bolt-in axle corporate 8.5 housings, all came out of '71-76 A-bodys. Nearly all local factory stock circle track guys used to run '73-77 A-bodys, as a result, the bolt-in axle rears out of these did not last long in the crusher yards. Occasionally have built the 73-77 version.
I talked to one of the techs at Strange and evidently the Mustang 8.8 blonaks they use have a longer pilot and close to the GM diameter. Not sure about getting the correct spline count on them.
Wonder if you could turn down the pilot 0.500 OD then just press on a bushing(with some Loctite) that is long enough like you buddy did. What are the GM pilots like 2.775-2.800 OD?
FWIW........BOP rear end strength is vastly increased using the LPW rear diff cover with bearing cap pre-load hardware.
The rear-end in my '79 t/a is factory stock and outlasted the 4 speed trans that grenaded under hard acceleration.
Home of WFO Hyperformance Shaker induction. |
I have a 77GP with a Buick rear that is a 8.5 with the press on axle bearings and backing plate. Would this be the same axle bearing that the 8.2 rears have? I always thought the ford ends were the way to go to eliminate the C-clips? |
I like the idea of buying 30 spline Mosier axles with the 71-72 olds stock size bearing and seals and installing the later model 30 spline posi, get a cheap junkyard 30 spline posi from a 89-95 ish Impala or Caprice or Roadmaster LT1 car. many are ex cop with posi, mate up to a cheap 3.42 or 3.73 gear set from a any 83 up to 2000+ model 1/2 gm pick up or suv. I built another narrowed 8.5 bolt in posi for a buddy's S10 that came from a 74 Cutlass, Mosier 30 spline axle was ordered and factory olds seal and bearing was used (installed by paul Peyton who narrowed housing, it worked. but I did a full spool instead on a set of GM 3.73's from a SUBURBAN, worked great.
63 Catalina coupe 467 cid budget drag car low 11's 1/4 , 7.0's 1/8th pump gas n/a 66 Star Chief Executive 59k mile 389 67 IH Scout project 2WD "Indian Scout" 69 Le Mans 2 dr HT 350 91k mile 15 sec 1/4 69 Firebird 400 Burgandy/Black 70 Olds Rallye 350 F85 4 speed 3.91's 70 Olds Cutlass Cruiser Red Wagon 350 108k miles 15 sec 1/4 12 sec w 455 74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8 2020 RAM 1500 SLT 4x4 5.7 A8 Hemi 2008 Saab 9-3 2.0T convertible |
I build alot of rear ends in the course of my business, I also have customers running into the 10's with 8.5 eaton clutch type posi's w/30 spline axles, studded caps and the heavy duty rear cover. Someone mentioned tru-tracks early in this thread, I have had customers break them with vortec 350's in bone stock z-71's so I refuse to install them anymore. As far as newer factory posi's, they are total junk, the gov lock governor usually loses the teeth and is laying in the bottom the first time someone spins there tires hard, more junk that should be avoided. I have probably rebuilt 200 chevy truck 8.5's in past 15 years after GM decided to bore out the factory carrier and install 30 spline axles to fix a non-existent problem. The factory carrier shears off the side shoulder where the side bearing is pressed on, then the ring and pinion usually self destructs while the owner keeps driving it with the axle centering the differential, these parts shopuld be avoided also, Smitty
"Cliff, thanks for the you tube link. Very impressive! will send you a PM."
Thanks. I would also mention, that we're running pretty "soft" to stay roll bar legal. Timing is retarded a few degrees, added some weight, and shifting at 5000rpm's. The car is a blast to drive on the street, quiet, smooth idle, drives like grand-ma's station wagon from stop light to stop light.....Cliff
Ditto to Smitty's mention above on gov-bombs... , i only mentioned the auburn cone style posis in the lt1 fullsize cars as a cheap source for junkyard build 30 spline 8.5 a body rear, a new eaton is my first choice too or a full spool
I've recently acquired a 1979 Cadillac Seville and was told it was a posi. I pulled off the rear cover and it has the S-spring carrier. Is this an Eaton or an Auburn? I counted the teeth at ended up with 47-21 which I think is 2:24. Wow! Talk about highway gears. I got the car cheap and mostly interested in the BOP TH400.
S spring carrier is known as the Corporate S spring posi. While its a clutch type posi, like an Eaton, no internals interchange. In Pick-N-Pulls I used to pull all the mid 78-79 Seville rears I could for housings, posis, disc brackets & disc calpers. Pitch the 5 on 5 stuff & grab some Nova axles. Have never ran across an 8.5 gear higher ratio than a 2.41. Most Sevilles had a 2.56's
