| THE LOBBY A gathering place. Introductions, sports, showin' off your ride, birthday-anniversary-milestone, achievements, family oriented humor. |
In the northeast with all the salt and brine they put down its just a matter of time for any piece of metal to rust. Don't get caught behind a brine truck or a road that is still wet with brine. That straight spray gets everywhere.
2007 Norwalk Quick 16 Winner 8.960 @152.24 8.96 dial http://www.youtube.com/watch?v=8HY_nJR9Aa0&NR=1 |
Had Towncar #2 rear brakes fail (under me driverseat) while commuting bumper-bumper traffic. Foot-brake the EMERG brake was mandatory. Step-son bought me a big coil of green brake-line & been using that to replace the brakes lines. Flare-fittings are fine, ferrule-not-legal, overall splices are not supposed to be "legaL' but I dunno how that really goes. I suppose a Flare-Flare in to a union is a junction, not a splice. |
Talked to my brother today and he's forming and flaring his own stainless brake lines. I offered to buy him new lines but he refused.
I told him that compression fittings are not legal so he agreed not to use them. The guy at Pep Boys told him to use them. Rob
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int 1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int 1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int |
be a simple...kinda man. |
Compression fittings are also a NO NO.
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
GM has had the brake line problem for years.
My son almost rearended another vehicle towing back from Norwalk last year. Friends pickup also failed. Lines sit on top of the frame and the corrosion starts. I did a search and one that I found, dealer said because of the salt. Truck was 4 years old and never left the Carolinas. We repaired my son's on the road then he ordered the prebent stainless kit and replaced them all. |
...I got original brake line off rusted old Pontiacs that got reused and still work.
...Brake line coils come coated with this super GREEN coating. I'm convinced the rusty brake lines [ in Production since 1994 to TODAY ] are: 1. a major liability. 2. a corporate sabotage. 3. bad Company leadership, QC, production-control engineering. 4. the wrong way to implement planned-obsolecense. |
Amen to that. My 2003 2500HD gets a brake inspection every time the oil gets changed. There seems to be something wrong with the metal used in thar era vehicles. I've heard of a few of my friends say the same.
ONE FLAG, ONE LANGUAGE, ONE NATION UNDER GOD!!! A proud Veteran who is the proud son of a Veteran and the proud father of a Veteran ![]() "Political Correctness: A doctrine fostered by a delusional, illogical, liberal minority, and rabidly promoted by an unscrupulous mainstream media; which holds forth the proposition that it is entirely possible to pick up a turd by the clean end. |
You're probably not going to believe this but... I was driving my girls to their basketball game today in the wifes 2001 Durango RT and the brake pedal went to the floor!!
Yep.. blew out the rear brake line! WTF is the matter with the car manufacturers these days?? That could've killed my whole family! Anyone know who makes a pre-bent stainless steel brake line kit for a 2001 Durango RT AWD??
use dot 5 in the bird as well
" Long may we DRIVE !" |
First place i tell people buying a used truck to look is right there. I mist oil under my truck, but that area I brushed waterproof grease all over it and all is well
saw many destroyed good luck with getting parts
Figures that it's classified as a clunker. It's been the best car I've ever owned.
10 years 100k miles and all I've done (outside of normal fluid and filter changes/flushes) is replace the battery, belt, tires, front brakes, shocks, the drivers window regulator (tried to lower the window when it was iced in place) and replaced the speakers (my fault hehe). Now I'm looking at a set of brake lines. Not bad if you ask me.
12-13 around town and 18 on the highway when I behave myself. Best riding and most comfortable SUV I've ever been in. My 1995 GMC Sierra got about the same. My 90 454SS pickup is 8-9 around town (I never drive it on the highway long enough to get the mpg).
I ordered a new 2012 Durango RT and it will be here in a couple weeks. We'll see what that one gets.
dont use DOT 5 on ABS sytems
I can make a line if I had a pattern
#38
There may be another reason that these lines are failing prematurely other than composition of materials, road salt etc. The ABS system pulsing the brakes I would think has something to do with the premature failure also, spiking any hydraulic line as an ABS system does will find the weakest spots in a system.
I worked in a plastics shop in the maintenance department and the presses we had that would slam valves shut suddenly would invariably be the machines the high pressure feed lines off of the pump ruptured and that would crack and split. There is more than corrosion or substandard materials that's causing line failure in as has been portrayed here many of the big three products, it's not just one manufacturer or particular model that is showing failures from what has been posted. I would be interested in how much higher line pressure spikes are as opposed to the same system without ABS. |
#39
Replaced them all with high pressure rubber lines and never had a blowout after that. The lines MAY be too rigid to handle the spikes.
Why is he not suspended? Last edited by sleepy; 01-29-2012 at 12:57 PM. |
#40
Interesting point. The rear line on the Durango blew as I was braking over some rumble strips. I didn't hear the ABS pump go offf but the noise of the rumble strip may have masked it.
Another idea I have is that there might be some cavitation going on in the discharge side of the pump and lines. If the pump inlet doesn't have enough positive pressure, micro cavitation bubbles will form within the pump. When these bubbles hit the discharge side of the pump, they are exposed to the pressure in the downstream side of the braking system and will collapse. The surface tension and energy released by a collapsing cavitation bubble slamming into steel is very powerfull and will easily erode/severly damage steel lines. For example, there's a video of a crab that uses cavitation bubble implosions to stuns it's prey. The crab closes his claw so fast that a bubble is formed and the shock wave from the implosion knocks the fish out cold. They put this crab in a fish tank with 1" thick glass walls and the force of the implosions broke the glass!! At work, we do countless pump and hydraulic system qualification tests to insure that our pumps do not cavitate. Cavitation can destroy a pump in a matter of seconds. I wonder if the car companies ever test for ABS cavitation?
