Old 06-10-2012, 09:01 AM
KARGUY KARGUY is offline
69GTO
Have you finished the exhaust system ? I am interested in the pipe routing. Any other
advise to others on this project.
Old 06-10-2012, 09:09 AM
Hammertime Mike's Avatar
Hammertime Mike Hammertime Mike is offline
Send a message via ICQ to Hammertime Mike
I like the work that you've done. Pontiac motors work great in trucks. TORQUE TORQUE TORQUE !!
Old 06-10-2012, 09:12 AM
Stuckinda60s Stuckinda60s is offline
Ya know, after all the times I've viewed this thread, it just dawned on me that you're doing this in Iceland. That impresses me even more, you don't have an easy access to parts or support.
MORE KUDOS!
Rich
The real democratic American idea is, not that every man shall be on a level with every other man, but that every man shall have liberty to be what God made him, without hindrance.
Henry Ward Beecher
"The problem with socialism is that you eventually run out of other people's money." Margaret Thatcher
Old 06-11-2012, 05:28 AM
RUDOLFSSON's Avatar
RUDOLFSSON RUDOLFSSON is offline
Thanks guys! No exhaust work yet.... working on trans and rear as is.
Old 07-09-2012, 08:11 PM
RUDOLFSSON's Avatar
Shorty 12 bolt truck style rear. 3.08:1 gears, passenger 12 bolt 3 series Eaton Posi (had to machine minor clearance to make it fit), big Ford bearing style ends (cut out of billet), 30 spline Strange axles, BOP brakes from a 8.2 rear and lightened 7.5 S10 drums.
What a cocktail... LOL
Old 07-10-2012, 03:48 PM
Donovan Donovan is offline
Check it out. For exhaust you can purchase a system here-
http://www.summitracing.com/parts/SUM-680125/
Product Line Summit Racing® Header-Back Dual Exhaust Systems
Summit Racing Part Number SUM-680125
System Material Steel
Exit Quantity Two
Exit Location Split side
System Finish Aluminized
System Style Header-back
Muffler Included Yes
Muffler Quantity One
Muffler Configuration Dual inlet/Dual outlet
Muffler Style Chambered
Exhaust Type Dual in/Dual out
Hardware Included Yes
Inlet Quantity Two
Intermediate Pipe Diameter (in) 2.500 in.
Tailpipe Diameter (in) 2.500 in.
Tip Included No
Quantity Sold as a kit.
Notes This product was designed for use with Hedman long tube V8 swap headers and Trans Dapt mount systems. Any other combinations will require modification. For off-road race use only.
Old 07-10-2012, 06:56 PM
RUDOLFSSON's Avatar
Thanks for the link... That looks like a good deal, I'll look into it. I was hoping to use some old scrap I have in the shop. I'll keep you guys posted!
Kris.
Old 07-12-2012, 12:15 PM
Kris.
welcome
there is another system offered by them with longer head pipes to mate to shorty headers. It may work better for you to adapt to manifolds. It's the same price as well.
http://www.summitracing.com/parts/SUM-680126/
Nice option if you don't have enough scraps.
Old 07-27-2012, 04:11 PM
RUDOLFSSON's Avatar
Fired it up for the first time today.... Will post pics of the exhaust later. I installed a factory exhaust (almost direct fit) from a 2004 LQ4 Hummer and connected it to the pontiac manifolds with mandrel bent pipes.
Old 07-27-2012, 07:11 PM
That's just too cool!
A little (Unsolicited, I know) advice. Sell the Holley and get a Quadrajet for it. Preferably one done up by someone like Cliff Ruggles.
You'll probably end up with more power and you'll definitely enjoy better mileage.
Rich
Henry Ward Beecher
Old 07-27-2012, 08:36 PM
Pontiacmuscle's Avatar
Pontiacmuscle Pontiacmuscle is offline
Send a message via Yahoo to Pontiacmuscle
VERY Nicely done!!! Looking forward to seeing more...maybe a video?? DROOL!
ARROWHEAD ADDICTION: An incureable disease contracted from the pointed edge of classic pontiacmuscle; all consuming, taking over mind, body and soul.
Old 07-28-2012, 10:19 AM
RUDOLFSSON's Avatar
Yes a q-jet would be better no question about that... I just have the holley on it for now, will do the change later when the car is all finished up.
Old 07-28-2012, 05:50 PM
bad ass
Well done with the hummer exhaust, love it!
Old 08-13-2012, 02:40 PM
RUDOLFSSON's Avatar
Man I need to put up some fresh pics.. It's almost complete, just put it on 4 corner weights and looks like it will weight 2900lbs w/o driver!! That's nice considering all the heavy street parts that are on it ( 18" wheels, all steel, factory manifolds, factory hummer exhaust etc).
I'm putting a service replacement SD '74 Q-jet on it with electric choke, fresh rebuild kit and new primary rods from Cliff... I'm excited to test it out with the new carb
Old 08-13-2012, 03:42 PM
It sounds like a great ride! Potentially good mileage coupled with respectable power.
Rich
Henry Ward Beecher
Old 08-14-2012, 07:46 AM
Overkillphil's Avatar
The Hedman shorty Pontiac headers may be justified in this case once your ready to dump the logs. Very nicely executed project!
Old 08-14-2012, 11:06 AM
what did the weight look like on each corner?
  #38
Old 08-14-2012, 04:18 PM
paul s.'s Avatar
paul s. paul s. is offline
VERY NICE WORK!
Sandoval Performance
www.sandovalperformance.com
Pontiac Crate Engines
CNC Edelbrock heads
Custom Ground Cams
JOHNSON Limited Travel Hydraulic Roller Lifters
  #39
Old 08-15-2012, 04:05 AM
RUDOLFSSON's Avatar
It was like 59% front.. and pretty equal +/- 20 pounds between sides. I didn't write the info down since it's not 100% done yet. It's got the battery in the front and heavy stuff up front so that explains the front % numbers. But hey it's a street car! A car like this gutted out with e-headed motor and glide should be 2500lbs easy.
  #40
Old 08-15-2012, 09:13 AM
rohrt rohrt is offline
Love it!
What are the rims?
