Old 03-09-2012, 03:41 PM
grandville455's Avatar
grandville455 grandville455 is offline
The one pattern looks ok? But If u look at the other to the right it is quite far down the valve tip, I would go about .100 shorter also..
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,[email protected]@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected]
M/T 275/60 ET SS Drag Radial
2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's
Old 03-09-2012, 03:46 PM
Steve C. Steve C. is offline
"If you are concerned with the location of the roller rocker sweep path and are convinced that it should be centered, there are steps you can take to improve the situation."
Rocker Arm Geometry And Valvetrain Alignment
A Detailed Explanation Of Valvetrain Alignment Goals
http://www.circletrack.com/techartic...y/viewall.html
Old information here:
Old 03-09-2012, 04:23 PM
llwta76 llwta76 is offline
Originally Posted by GR8ONE68 View Post
Ok, I've been thinking about this and I think I have it figured out. At first glance, I would think that the push rod is too short. But thinking it through, I think it has to do with which side of center the contact point (rocker to valve stem) is on. If the contact point is less than 90 degrees (3 0'clock if the rocker stud is pointing at 12), a shorter rod will bring the wear pattern closer to center on the valve stem. If the contact point were greater than 90 degrees, a shorter rod would push the wear pattern out closer to the exhaust manifold.
Is my thinking correct or am I over complicating it? Sorry for the hijack, but this post got me thinking about it.
Assuming a given engine w/the same valve train parts a shorter PR will move the contact pattern AWAY from the exh. side while a longer PR will move the pattern TOWARD the exh. side. Centering this pattern on the valve tip insures maximum valve guide wear while bad valve train geometry will cause accelerated guide wear.
Old 03-09-2012, 11:46 PM
cutlas cutlas is offline
9.15" it is.
I re-checked my pushrod length using 9.1", 9.15", and 9.2".
9.1" gave me a pattern about center.
9.15" gave me a pattern just to the exhaust side of center.
These checks where with a hydraulic lifter pumped up and a week check spring.
My thinking is with my lifter pre-load added in, 9.15" should be just about wright.
Watching the rocker arm move through its stroke, 9.1" seemed to give a more even movement looking closer to 90deg at 50% lift.
Any one have a good set of 9.15" pushrods with at least .080" wall for sale?
1967 Firebird project in the works
400, 670 heads, 2802 cam, Hooker comp, Crosswind intake, Quadrajet, 700r4, 3.42 Posi.
Old 03-11-2012, 02:18 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
"Are you saying if your combo needs more lift all we need is longer pushrods?"
No I am not, just saying go measure one with several different lengths and dial indicator or pull op Pete's old article where they did that and it will more than just a few thou either direction. It does impact it just as swapping to different rocker brand can even if the ratio is identical as they use different roller tip diameters, and different geometry for the pushrod cup height vs fulcrum and roller tip. I have measured total lift while checking pushtod lengths and it definitely changes.
Skip Fix
Old 04-26-2012, 09:58 PM
78w72 78w72 is offline
Originally Posted by Skip Fix View Post
So how do you guys using hydraulic rollers do this?? Get an extra and make it solid?
Anybody?? I'm going to be installing a hydraulic roller cam soon, and I am confused as how to measure for correct push rod length. I was told I can't use a solid roller lifter as a "checking" lifter because it is way shorter than a hyd roller lifter, so what is the secret?
Old 04-26-2012, 10:09 PM
Rodney R's Avatar
Rodney R Rodney R is offline
I'm using all comp stuff for my build. For length, I bought a comp shelling rod and solid lifter. The seat height on the hydraulic is 2.49 and the Solid is 2.01. When measuring with the solid roller, I just add .48 to make up for the difference. I've heard that different companies may measure a tiny bit different, possibly giving you a variation of .1 on the measurements. Stick with one brand and you'll be fine. Just requires a little math
Old 04-27-2012, 09:46 AM
Thanks for the response. Some questions:
1. Is a "shelling" rod the push rod measuring tool?
2. Don't you mean subtract the .48" difference, to get the correct push rod length?
3. How tight do you make the rocker arm stud nut -- just to zero lash?
4. Do you have to compensate for the extra 1/2 (approx.) turn past zero lash that you do with hyd lifters? If so, how?
