The short answer is no. The long answer is it doesn't need to, as it protects steel in a different manner than a moisture-cure urethane. Moisture cure urethanes provide a very tight film when cured whereas an epoxy primer (and most other primer types)with a much higher P/B ratio(pigment to binder) tend to be somewhat porous. Most also contain some kind of zinc compound (usually zinc phosphate nowadays) which acts as a "sacrificial" pigment, expending itself to protect the steel it is coated on. And when water permeates a painted surface (and this happens every time your car sits out in the rain) a certain amount of moisture may seep all the way down to the steel substrate. If there are no contaminants for it to react with (water-soluble salts, rust, etc) the water will come back out, no harm done. A tighter film may actually repel the water, not letting it permeate at all. Eventually both types (and all other)coatings will fail. My issue with "Paint-over-rust" type products (and I've made it known on this forum before) is not so much the chemistry (moisture-cures can and do work well, my company sells alot of them) but the marketing and the chance of success for the average home-restorer. Epoxy is much safer to spray, and is virtually fool-proof assuming the substrate is clean and rust-free. MDI based paints seem to work very well when they work. But how can you tell? Some companies say remove loose rust, some say remove all rust and pretreat (why not use epoxy then?). When it fails, it can come off like powder coat (in sheets, because the film cohesion is much greater than its adhesion) I will admit for enclosed areas, it is certainly better than nothing, and probably better than what the factory did (7-stage wash/pretreatment only) and I see nothing wrong withh pouring into a deck lid as the above poster mentioned. But if I can clean the steel and spray epoxy, I will do that everytime over moisture-cures and powder. I don't have many issues with powder paint either, per se, but rather with some powder shops that don't properly clean/treat the substrate and/or undercure thier powder thru thier bake oven. Sorry, I digress.
