Brian, I agree but my 455 went 465 rwhp and ran 10.90. I'm sure I will eventually get 560+ rwhp and at least be able to cover a 10.20 1/4 Mi. then drive it home listening to classic rock. As of right now I have +90 hp and + 50 lbs tq from the old combo. Will that get me to a 10.20? Time will tell for sure. The torque peak was 4950-5000 rpm and the HP peak was 6200 and very flat, which I think is good for overall averages. The split between the HP and TQ was about 1200 rpms. As I'm gathering all this data I'm trying to figure out if I could go up to a 1250 carb, as mentioned earlier, and /or is the intake doing its job based on cam dimensions, cubic inches, HP and TQ peaks. I feel i'm an adaquate tuner but I also know i'm amongst real pro's and will listen to sound advise.
Steve |
That 1050 carb is too small for that motors intake needs, and that 1" of vac proves it.
you will pick up 30 HP with a 1250 carb thats jetted right!
Based of the mph on the dyno sheet, at 6000 rpm you have 14% slip. That's a lot.
Less said,,,,,,,, Less mended. |
Tin, it certainly feels like it wants to leap off the dyno. The converter was tightened up a bit from the 4000 stall that it was, but I think you bring up a good point, something for me to investigate. I will just leave it hooked up to the dyno till this weekend and try it again. How much slip is acceptable at top end?
Steve |
The smart move would be to call Ceralli Comp. if you have questions about how to improve it.
DOC'S TA Turbo 535, CV 1 heads. Built by Cerralli Competition Engines Tenth Anniversary (Van Nuys) restored. Tenth Anniversary Barn Find (Norwood) Both 4 speeds! |
