Old 07-03-2012, 09:29 PM
Held for Ransom's Avatar
Held for Ransom Held for Ransom is online now
More...
ID:	289833   Click image for larger version
ID:	289834   Click image for larger version
ID:	289835   Click image for larger version
Old 07-03-2012, 10:52 PM
Formulabruce's Avatar
Thanks HFR!. I know I have been confusing the 73 and 4 for a while now. Great Pics!
Old 07-03-2012, 10:55 PM
thefirebirdm@n's Avatar
thefirebirdm@n thefirebirdm@n is offline
Send a message via MSN to thefirebirdm@n
Would have loved to have helped on this one but my '73 did not have a factory base.
Jimmy
www.firebirdgallery.com
2002 WS6 M6 Trans Am - original owner
1973 Trans Am 455/4-speed
1971 Formula 400/400
1969 GTO 400/400 - 3rd owner
1968 Firebird Convertible 350/200R4
POCI - AAC
Old 07-03-2012, 11:15 PM
The Boss's Avatar
The Boss The Boss is offline
Originally Posted by Brewster View Post
Mike is this the shaker your looking for?
We're going to need more pictures. How about from the top down & from the bottom up.
And go racin' in the street.
Old 07-03-2012, 11:42 PM
Brewster's Avatar
Brewster Brewster is offline
Ahhh, the guy watching these parts would NOT have dug that. I think he was worried about getting Top Dollar or something???
Old 07-04-2012, 08:35 AM
The Boss's Avatar
Well you gotta have the bucks if you want to get the best parts.
Old 07-04-2012, 09:32 AM
Thanks for deciphering this Mike!
Is '75 T/A base, same as '76 T/A, or 78-79 W72 T/A
Have a bunch of T/A bases to go through
With the holiday tomorrow and it being too hot to do anything too strenuous, I thought I'd revisit this. Please correct with exceptions. For people shopping eBay, learn here on what questions to ask...
4 barrel Firebird/Formula/Trans Am base will have almost no gap (approx. .16”(1 dime and 2 pennies)) between center hump and straight edge when you lay it across the top. Sensor and carb. vent hole should be across from, not next to, each other.
1973
Has three welded clips for vacuum hoses.
Hole for screw to hold fresh air duct is circular and only on top side.
Sensor is black.
Air flap pin exits to the right.
Trans Am PN decal (Keep your GM car all GM) is located between snorkel and indent.
Measurement between snorkel and air breather hole is 15”.
Formula PN decal (Keep your GM car all GM) is located between air breather and indent.
Measurement between snorkel and air breather hole is 14-1/2”.
1974
Went to four welded clips.
Sensor went to painted black.
Air flap pin exits to the left.
1975
Hole for screw to hold fresh air duct went oval on both sides.
Added a hole in side for vacuum switch.
Old 07-04-2012, 10:57 AM
REEDRACER's Avatar
REEDRACER REEDRACER is offline
This is great info! Thanks! I am going to need one for a 73.
69 Judge RAIII 4SP 2ND OWNER
63 Catalina 421HO 4sp
66 GTO Conv 4sp
73 Trans Am 455 4sp
http://www.sdperformance.com/
Drag racing. An adrenalin rush like no other. It felt like going into combat, tasting your first beer, and losing you virginity, all in about 8 seconds.
Old 07-05-2012, 04:57 PM
Roger,
I believe a '75 TA base would look like a '75 Formula base with the air breather hole positioned differently.
I think '76 got the added valve in the base bottom. And, possibly, another clip added to the side of the air cleaner.
Also the lid went from the 13-1/8" diam. to the 14-1/16" diam. at some point.
Old 05-03-2014, 06:43 PM
http://cgi.ebay.com/ws/eBayISAPI.dll...m=251521644958
Someone didn't do their homework...
$300, and with no lid? Suckers born every minute.
Old 05-03-2014, 08:10 PM
The seller also seems to be a little confused as to what he's selling. A few examples from his current sale listings.
Following is a '71-72 Formula 400/ Formula 455 D port base
(have a few, not for sale)
http://www.ebay.com/itm/1970-72-TRAN...item3a8fdb4c0a
Following is a '69 or '69 Olds piece (have a few, sale or trade).
http://www.ebay.com/itm/1968-72-GTO-...item3a8fdb6ad7
Note the ribs in the snorkels & the position of the crankcase filter on the base 442 aircleaner. '68-69 Pontiac & '70 Pontiac, the Buick single snorkel, & the '68-69 Olds versions are ALL different from each other.
Old 05-03-2014, 10:13 PM
2manyT/A'S's Avatar
Irregardless of the price paid....it seems to be a pretty nice piece
Finding ones that haven't had water sitting them for years is not easy....around here,anyways....
Eye Candy......garage band?
Go full screen & turn it UP!
Old 05-03-2014, 11:28 PM
I have a question about the air cleaner bases to. I have a base that I think it cake from a T/A but not sure. I've had it for a LONG time. It is the typical 16" base with a single snout. The end of the snout is about 3 1/2 inches wide on the end & it has 4 of the vac. hose clips , with the indentation on the side of it (where the dist sits) Has a place for 2 sensors on the inside of the base, 1 is for a sensor with a single hole post, & then 1 with 2 posts , both would come through the base for vac. lines to be attached. Also has the 1/2 or so hole for where the air port on the top of the cabs would come through it. Can anyone tell me what this base should fit. The smaller snout end is what is confusing me. As i said I've had this for a long time & am not sure about it. Any help ?????
Old 05-03-2014, 11:57 PM
2manyT/A'S's Avatar
Whole lot simpler/easier if you post a few pics...............
Old 05-04-2014, 12:34 AM
I'll get a few & have them on tomorrow so you guys can help, sorry for the long winded description but was hoping someone would know from that but I kinda knew I should have had a few pics.
Old 05-04-2014, 01:55 AM
Default Pic's of the air cleaner base
Ok guys here the pics of the air cleaner base that I need help in identifying I have had it for a long time & don't remember what I got it off of. I had it tagged at one time but when I cleaned & painted it , well the tag got blown off in the sand blaster & I need help. Thanks in advance . I don't know if you can tell it does have 3 hols in the side The hole closest to the snout has a hole that looks kinda like a key slot. & it has a baffel in it just inside the snout as in pic 4 . The end of the snout is about 3 1/2 inches wide at the outer end.
ID:	362318   Click image for larger version
ID:	362319   Click image for larger version
ID:	362320   Click image for larger version
ID:	362321   Click image for larger version
Old 05-04-2014, 02:06 AM
2manyT/A'S's Avatar
Don't think it's a Pontiac unless 80-81 non-Turbo 301?
There is no hole for float bowl vent tube so that would eliminate 70-79 350,400 & 455 Pontiacs..........
Perhaps 70's chevy A body,pick-up or van?
  #38
Old 05-04-2014, 07:07 AM
It's nice looking because it's not a Trans Am base (always ask yourself why is there no lid). The crankcase vent tube won't work unless they use/have a non-TA unit. Still too much money, IMO.
  #39
Old 05-04-2014, 07:10 AM
Rex, I'm not familiar with the one you've posted. Maybe a small block chevy unit (they put them in Firebirds too, right?).
  #40
Old 05-04-2014, 05:18 PM
Sort of doesn't look like it has enough "drop" around carb to be Bird.
Didn't notice any indents for distributor clearance.
dunno what it is
