I have the tube going accrost the carbs with a slot at the top done. I will see if I can find some plug boots also if this don't work. I'll have to look at these Demon fuel bowls and see if they are the same on both ends. I had the fuel level slightly below half way in the sights since Demons are in the middle of the glass window. Also thinking of making a single 4 top for the intake and some 1295 sleeves. Always can put the Victor back on for Tri-Power if I can't get this working right.
Todd Sedlmeier Who ever thought pinewood derby cars would lead to this! October 2004 HPP Shootout participate http://www.highperformancepontiac.co...out/index.html 86 Grand Prix 535 High Port 8.93 @ 153 65 GTO 433 High Port 12.04 @ 113 |
When I had my alcohol Dominator mounted sideways I tried the angle floats. The reason I tried them was it was laying over after the shift. It was going lean. It ended up the fuel pressure was real low. Anyway the angle floats made it worse so I swapped them back to the regular floats. Found the problem and left the regular ones in. In my opinion you won't see any benefit going to the angled floats. But I guess it won't hurt to try it.
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0 2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion and 2015 IHRA Div 5 Mod champion 2024 Chief of the Pontiacs |
LMSRACER
i adjusted fuel level as per instructions , no extensions on vent , slosh tubes . i dont know why they sloshed fuel out vent tubes but this fixed both pair of carbs i ran , first were a set of 750 cfm next were 1050 domis both had same problem . they would start fine rev and run in pits fine upon launch they would flood for an instant then clear up and run like a scalded dog . hill461 |
Hill461 what are you using now?
RA462
i am currently running the same 541 ci ia2 ,fully ported tiger heads , port matched ia single four intake with a 1450 cfm carb . best pass on this combo is 5.42 @ 128 in 1\8 mile. hill461 |
