Old 08-23-2012, 11:47 AM
Stuckinda60s Stuckinda60s is offline
I've always used a proper-sized hose on each nipple with a pipe plug threaded into the hose and a couple of hose clamps holding everything together. They work great and last for years.
The beauties of doing it that way are that you don't have to take a chance by modifying the timing cover and that it will work on a corroded nipple.
Rich
The real democratic American idea is, not that every man shall be on a level with every other man, but that every man shall have liberty to be what God made him, without hindrance.
Henry Ward Beecher
"The problem with socialism is that you eventually run out of other people's money." Margaret Thatcher
Old 08-23-2012, 02:14 PM
grandville455's Avatar
grandville455 grandville455 is offline
What would happen if u plugged that nipple back on the passenger head, and also the one on the pump? So U just had the top and bottom hoses, And the stat drilled for some bypass water, the bypass still hooked up to crossover too.Would it run hotter in the heads?
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,[email protected]@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected]
M/T 275/60 ET SS Drag Radial
2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's
Old 08-23-2012, 03:00 PM
Skip Fix's Avatar
Skip Fix Skip Fix is online now
I NPT tapped mine to run an adapter for AN lines for the heater. Been there darned near 20 years now.
Skip Fix
Old 08-23-2012, 04:32 PM
GTOLou GTOLou is offline
Yeah - a lot of us run the back passenger head plugged and the heater nipple next to the water pump plugged (no coolant through the heater core). Anyone know the effects? I've not noticed any issues, but I don't run super high compression ratio engines either..
Old 08-23-2012, 08:45 PM
That's what I was talking about. There aren't any ill effects, other than no heater and the loss of the heater core as an emergency cooler for a hot engine. You don't need a hole in the thermostat, either, the pump can be dead-headed without ill effect.
Rich
Henry Ward Beecher
