I'll post pix tomorrow, I can't right now, the car's at my shop and I'm not there right now.
GREG'S GOATS: 1970 GTO Judge RA-III, 4-SPD & A/C. Power Windows, Power Seat, Power Brakes, Steering, AM/FM, 8-Track, Formula Wheel, Rallye Gauges, Remote Mirror, Numbers Matching. Assembled at Pontiac, MI Plant 5/26/1970. 1968 GTO 461 CI, RA-III heads, Hotchkis springs, UMI suspension, Bilstein shocks, 12-bolt 3.73's. 1966 GTO Ragtop 4-Speed, AM/FM, Original driveline. |
You were smart to bend it before you put in on the car. Glad it worked out for you.
Greg Reid Palmetto, Georgia |
It's pretty much the same as Greg's, and I had the same problem with the filler neck. I had to bend it to make it fit the opening in the bumper. Wasn't too bad. If I had it to do all over again I would have gone to Advance. Frankly, I never thought of that at the time.
It worked out pretty well...
Bumping an ancient thread! I am in need of a new gas tank for my '68 Lemans. The original tank was fine, but I removed it when I was planning to go with an in-tank pump. I got the new tank and gave the old one away. Now I have changed my mind on the in-tank pump and need an original type tank.
My question - does anyone manufacture a correct '68 tank? I know I can modify a '69 tank and I'm ok with that; I'd just prefer something ready to bolt in if it's available. Thanks, Scott
Please check out my YouTube channel for vintage/classic car and truck builds and shenanigans! https://www.youtube.com/watch?v=jq61KxKp1Is&t=14s |
the 69 style works fine & Spectra made a nice looking & fitting tank. you just have to bend the filler neck up a bit to have it sit where its supposed to in a 68, but its really no big deal. The one I bought was made in the Spectra Canada plant. I was very happy with it. I assume they still make them there?
![]() 68 GTO 4-spd Convertible 78 S/E Trans am L78, WS6 Auto 78 S/E Trans am W72, WS6 Auto 79 10th aniv W72 Trans am 80 Indy pace car Trans am 89 Trans am GTA |
| The Following User Says Thank You to 68ragtop For This Useful Post: | ||
Here's a later thread to show a simpler way to get the '69 neck aligned with the '68 bumper opening. Very easy but you have to keep a close watch on the solder joint. It could be touched up easily with a butane torch or big watt soldering iron if necessary.
https://forums.maxperformanceinc.com...ht=Filler+neck
| The Following User Says Thank You to Greg Reid For This Useful Post: | ||
Ames sells the correct tank with neck for 68 . I just put one in mine early this year . They have a stainless version too . Part # L205R
| The Following 2 Users Say Thank You to locomotivebreath For This Useful Post: | ||
Scott
It's about time someone did that.
Got it installed this weekend. The neck was surprisingly easy to bend.
| The Following User Says Thank You to bulletpruf For This Useful Post: | ||
Good deal. Make sure that there's no spider web cracks in the solder.
