Old 01-27-2013, 11:59 AM
TOP 452's Avatar
TOP 452 TOP 452 is offline
Send a message via Yahoo to TOP 452
John is still in. Had a bye run 5.14 @ 133 plus.
Old 01-27-2013, 12:33 PM
bad69bird's Avatar
bad69bird bad69bird is offline
Congrats John! Pontiac Power!!!
East Coast Mafia TTFMF
Making CVWHAT's great again. I guess it took a deplorable ECM member to do it!
Originally Posted by Ray Cox View Post
Holly cow we must be some dume corn huskers here in indiana or somthing!!!
Fastest Blow-thru Pontiac powered car in the Country [email protected] (3465lbs)
Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: [email protected]/ [email protected] (3365lbs)
Old 01-27-2013, 12:42 PM
Scott Roberts Scott Roberts is offline
According to the rules posted, a Pontiac has to be 250lbs heavier then a BBC N/A?
Old 01-27-2013, 01:14 PM
john marcella john marcella is offline
Originally Posted by R 70 Judge View Post
Found this on the X275 website
Thanks,
Congrats to John he is flying for sure, but after reading those rules he better live it up wile he can. I think he will find him self about .2 slow within about 6 months. Maybe .3
I think this class will blow the F up
John Marcella
Marcella Manifolds Inc.
[email protected]
ph. 248-259-6696
Old 01-27-2013, 02:03 PM
R 70 Judge's Avatar
Originally Posted by Flyin79bird View Post
Those are X275 rules, not Ultra Street.
Yeah I messed it up.
Originally Posted by Sar94 View Post
Ultra Street Shootout
1/8th mile Eliminator
BODY:
Fiberglass/Carbon body panels are limited to hood, rear deck lid, fenders, doors, and bumpers. Cowl hoods may not be taller than half way point of the windshield. Forward facing scoops are prohibited on power adder combos unless factory installed or less than 5 inches from flat area of hood. Inlets for turbochargers and superchargers must not be exposed to ram air
INTERIOR:
Aftermarket steering columns are allowed. Factory type dash accepted. Must have carpet.
ELECTRICAL:
Optical devices are prohibited. All entries must have operational head lights and tail lights.
ENGINE:
Aftermarket blocks and cylinder heads are allowed. All entries must utilize a single carburetor cast intake manifold. Motor plates and solid mounts are allowed. Engine must be in stock location. Mufflers are required on all vehicles (except turbocharged combos). All SB power adder engines are limited to 440 cubic inches. SB N/A up to 480 cubic inch permitted with added 7 lbs. per cubic inch over 470 and BB N/A limited to 632 and BOP/BB Mopar power adder limited to 588. Any engine in question will be measured with a P&G gauge. A correction factor of 1.5% will be used. Competitors may be asked to remove a cylinder head for bore and stroke measurements should any discrepancies arise.
INDUCTION:
Small blocks and BB N/A combinations may use a single cast intake manifold with single carb or EFI. Small Block N/A may use cast tunnel ram/sheetmetal/dual carbs w/weight penalty (See*below)
POWER ADDERS:
Nitrous limited to SB and BOP/Mopar BB entries - Progressive nitrous controllers are allowed. Entries must utilize a single stage nitrous plate with one nitrous, one fuel and one redundant purge solenoid. Cross bar or perimeter style plate not permitted on BB Mopar entry. BB Mopar permitted single stage, single bar plate. Foggers must be disconnected and all solenoids must be capped off. Nitrous plates using fogger nozzles are not allowed.
Turbocharged (mid frame turbo only) and supercharged entries are limited to stock valve angle SB combos only. (SB CHEVY 23 DEGREE - SB FORD 20 DEGREE – 18 DEGREE MOPAR - FACTORY HEADED SMALL BLOCK FORD MOD MOTOR - LS CHEVY 15 DEGREE)
** NOTE: SB Chevy 23 degree Raised Runner – SB Ford 20 degree (SR20 –FT1 or T1RI or equivalent) not permitted with boosted combo
TRANSMISSION:
Any OEM style automatic or OEM manual transmission is allowed with power adder. Clutch assisted/clutchless manual transmission allowed on N/A. Manual transmissions must utilize SFI approved bell housing.
REAR SUSPENSION:
Stock type rear suspension or ladder bar only. Coil over shocks are allowed. Anti-roll allowed. Aftermarket replacement control arms are allowed. Stock frame rails must be in factory location, notching permitted. Corvette permitted any type of transverse leaf spring rear suspension. Wheelie bars are prohibited on all cars.
FRONT SUSPENSION:
Factory type front suspension only. Coil over shocks are allowed. Aftermarket replacement control arms are allowed. Aftermarket K-Members/Sub-Frames allowed.
WHEELS/TIRES:
A maximum of a 28 x 10.5 non W slick (N/A small block only), 28 x 12.50 ET Street or any 275 radial may be used on N/A, power adders limited to a P275/60-15 Mickey Thompson Tire P/N 3754R radial tire. Wheel width is limited to 12"
NITROUS WEIGHTS:
Base weight includes BOP combos – 3200
Mopar BB conventional B1 head - 3300
All heads 14.9 and under - 3250
Any canted valve head - 3250
All heads 15 degrees and above carry no additional weight
Any non-raised runner 23 degree combo – 3000
Any raised runner 23 degree combo - 3150
Blue Thunder Cylinder Heads - 3300
Any 20 degree ford – 3000
Any 20 degree high port SR20 –FT1 or T1RI or equivalent - 3150
TFS-R ford - 3100
SUPERCHARGER WEIGHTS:
F1A-3200
F1C – 3250
YSI – 3250
TURBO WEIGHTS:
T-76 - 3150
T-80 - 3200
N/A WEIGHTS:
N/A Inline head – 2650
N/A Non-Inline head – 2750
N/A (big block with standard deck height and conventional head) 2950 lbs
N/A (big block with tall deck height and conventional head) 3000 lbs
N/A (big block with standard height and big chief head) 3050 lbs
N/A (big block with tall deck height and big chief head) 3100 lbs over 589 add 100lbs
GENERAL:
No Billet cylinder heads/blocks
No Billet wheels on turbo combo
No Reducers on turbo or supercharged combo
Alcohol/E85 legal (meth injection legal on non-intercooled combo only)
All turbochargers (mid frame only) and superchargers must be as manufactured from factory
No muffler required on turbo entry, required on all other combos
No bull horns - front exit exhaust permitted but must not effect timing equipment
Gear driven supercharger allowed
Belt driven supercharger deduct 50 lbs
Boosted LS 15* add 50 lbs
Non Intercooled boosted combos deduct 50 lbs (no deduct if on Alcohol for fuel)
Leaf springs deduct 100lbs
*Cast Tunnel Ram/Sheetmetal/Dual Carbs on SB N/A add 50 lbs
Single 4150 carb/throttle body deduct 50lbs (N/A or NOS only)
N/A may deduct 100 lbs if using M/T 3754R tire
V6 entries deduct 200lb
Accepted Products
Accepted products deadline for Ultra Street/X275 Motorsports: Requests from manufacturers to have new products considered for addition to the 2013 season should be submitted before December 1, 2012 for the 2013 season. After this date, Ultra Street/X275 Motorsports will consider manufacturer requests for new products for the 2014 season.
Found these on yellow bullet.
James
1970 Trans Am
Old 01-27-2013, 02:06 PM
ventura7211's Avatar
ventura7211 ventura7211 is offline
Originally Posted by Jack Gifford View Post
I quit reading (and walk away...) when I see that rules contain the phrases "small block" and "big block".
Yeah, you run into that in classes that are not Pontiac only...
In x275, yes, because the weights listed a Pontiac combination would be using nitrous, probably via a fogger.
Yes, the rules posted are x275 rules, that class runs in the 4.60-4.80 range. These are the ultra street rules:
BODY:
INTERIOR:
ELECTRICAL:
ENGINE:
INDUCTION:
POWER ADDERS:
TRANSMISSION:
REAR SUSPENSION:
FRONT SUSPENSION:
WHEELS/TIRES:
NITROUS WEIGHTS:
TFS-R ford - 3100
F1A-3200
F1C – 3250
YSI – 3250
TURBO WEIGHTS:
T-76 - 3150
T-80 - 3200
N/A WEIGHTS:
GENERAL:
N/A entries get a weight break and get to use a better tire.
Old 01-27-2013, 03:59 PM
Jeff Kinsler's Avatar
Jeff Kinsler Jeff Kinsler is offline
Originally Posted by john marcella View Post
Thanks,
no, john sears says he will keep it in check.. LMFAO.
540 c.i. Ultra Street Combo
Tiger Heads with Tiger Intake
Induction Solutions fogger with .046s
1.079 4.52 155.15
3000 lbs
7.77 @ 169 1/4 Mile (2015) with EHTTFMF!!
7.17 @ 188 1/4 mile (2024)
Special Thanks to:
Ron at Rhodes Custom Auto
Butler Peformance
Jim Hostler's Transmissions (HOSGTO) on here
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
Old 01-27-2013, 04:08 PM
Ron H's Avatar
Ron H Ron H is offline
PPTTFMF Git r dun
68 Firebird
Are you running with the wind or breaking it?
Old 01-27-2013, 05:39 PM
LOL, This will be a 4.80 power adder class in no time at all!!!
John Marcella
[email protected]
ph. 248-259-6696
Old 01-27-2013, 09:08 PM
T Syron's Avatar
T Syron T Syron is offline
A little bit of ink in Dragzine.
http://www.dragzine.com/race-coverag...rom-bradenton/
Tom Syron
Old 01-27-2013, 09:39 PM
Flyin79bird's Avatar
Flyin79bird Flyin79bird is offline
Not sure what happened to him on his second pass but it looks like he either had trans issues or traction issues...car didn't seem to want to get going out of the hole. Needless to say the S-10 was on the bumper almost half way through the whole run. #9 took out our #1 qualifier.
68 Firebird "Indian Giver" 540 MR1, HP's, Wenzler -- For Sale $12,500 rolling Best of 5.12@134 on 175 shot
72 LeMans "POS" - Next US beast
Old 01-27-2013, 10:08 PM
no way on the old mickey. not gonna happen...
1.079 4.52 155.15
3000 lbs
Special Thanks to:
Butler Peformance
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
Old 01-27-2013, 11:19 PM
I keep forgetting about the old MT . But its probably still going to happen, WATCH.
John Marcella
[email protected]
ph. 248-259-6696
Old 01-28-2013, 02:04 AM
John is on the new MT Pro tire...you only have to use the old MT 3754 with a power adder.
Old 01-28-2013, 03:17 AM
harry k's Avatar
harry k harry k is offline
Send a message via AIM to harry k Send a message via MSN to harry k Send a message via Yahoo to harry k
http://www.youtube.com/watch?feature...8FDz7yZ3Q&NR=1
Is he a PY native ?
someone who thinks logically is a nice contrast to the real world.
http://www.youtube.com/watch?v=3FfKVVZW1-Y
Old 01-28-2013, 06:17 AM
Money Pit's Avatar
Money Pit Money Pit is offline
Originally Posted by harry k View Post
Yes, he chimes in once in awhile.
Old 01-28-2013, 09:28 AM
Troublemaker427's Avatar
Troublemaker427 Troublemaker427 is offline
"Thanks for the well wishes, had a good time, broke trans Friday which put us a little behind but it was nice to get a quick trip to Florida in this time of year! We are trying to get more passes on the car and our "race day" performance needs some work!!"
John posted this over on YB.
Jody Aberts
Troublemaker2
1966 Fairlane 427
AA/NSS
9:[email protected]
1964 Galaxie 500XL
390 p-code 4spd.
1966 F-100
390-C6
  #38
Old 01-28-2013, 01:57 PM
PN's Avatar
PN PN is offline
Well we tried to get a mini vacation in but ended up more work than planned!!
We are still driving home, but had a great time there were some Pontiac faithful helping us out down there, we pitted next to Russ White's motorhome and put them to work!! (John Gunther, Wayne Garrison and Bill) they wrenched, pushed, polished, and cooked all weekend!! Thanks Guys!!
The car was consistent for four straight runs (14,15,16,15 60's) so blowing the tires off caught me off guard, then I was convinced the guy in the other lane was going to join me in my lane.... Rookie mistake, should have tried to run him down I guess......Oh well maybe next time! Thanks for positive comments! Back to work
Ultrastreet / Real Street 275 65 GTO
570 IA2 Tiger Head/Single Carb NA
4.79@144, [email protected] - 2900#
Thanks to: Uratchko Racing Engines, John Marcella, CFM Performance, Allpontiac.com, BOP Engineering, PTC
  #39
Old 01-28-2013, 04:41 PM
60man's Avatar
60man 60man is offline
Sounds like a fun time..
You were hanging with a good group of guys for sure !!
No shortage of anything I'm sure..
Did Russ bring his "Indian Uprising" ??
ECM member.
MANDRA
  #40
Old 01-29-2013, 12:53 AM
bad69bird's Avatar
X2! Congrats John...that beast has come a long way!
