Old 05-31-2013, 03:32 PM
Cliff R's Avatar
Cliff R Cliff R is offline
It's going to depend on CID, compression ratio, and cam choice. If you provide me with the CID and compression ratio, I can specify a power piston spring that will work for what you are doing.....Cliff
Old 05-31-2013, 04:45 PM
1969GTO's Avatar
1969GTO 1969GTO is offline
Default Cliff [Ruggles]JET
Cliff, my Q-JET [you had built for me when I had a differnt cam] is now the SDPERFORMANCE Stump Puller.
The engine is a 400/462,just under 10.1comp.
SDPERFORMANCE [Ruggles] cast intake.
RamAir Restorations Ram Air manifolds[ceramic coated]
2 1/2 XPYPES exhaust.
The carb is that later year Buick 800 cfm with the APT adjustment.
Just a note to those reading this, I too at one time bought a Q-JET from Jegs,it did have the chevy fuel inlet and the carb ran like crap.
I did send it to Cliff [6yrs ago-ish] and he had a list of things not done to the carb as to where half the carb was working. [it was a piece of junk]
Cliff did repair the carb and it was great. But just think of all the added xtra cost of buying a newly-rebuilt carb and having to send it out to be made right.
Cliff is worth the wait
color me gone
Old 05-31-2013, 07:23 PM
android 211 android 211 is offline
Every time I type in 7029268 in ebay collector car parts one comes up. Unless your GP is a 4 speed, thats the right one for your car. They vary in price. There's a lot of them out there; they went on every standard engine 4 bbl automatic Pontiac in 69 with a 350, 400 or 428.
Old 06-01-2013, 06:58 AM
Cliff R's Avatar
The quality control of the "remanufactured" carburetors has went from "pathetic" to "not worth two squirts of duck poop" in recent years. They have so many problems I could write a book on them in this response.
Instead, I'll just say that we don't want any sent here, and are no longer working on them for any reason. In the amount of time I spend trying to get them up to par, I could have built at least two original "virgin" units from the ground up and ended up with perfect results right off the bench.
The "reman's" are so "hacked" up these days, and the castings are soft from the acid bath they get, we're just "polishing turds" trying to get them up to par for the customer.
I would also recommend for anyone reading this to avoid the electric choke Marine units being offered on Ebay. They are nicely painted black mid to late 70's Caddillac cores that are WAY, WAY off the mark for any Marine application. Had a few end up here in the last year or so, and don't want to see any more of them either.
A guy is better off to get his own core, some good parts, and go after the deal himself, than to throw good hard earned money at some generic/commercially remanufactured POS......IMHO......Cliff
Old 06-01-2013, 10:12 AM
1969GTO's Avatar
Default Power valve spring recomendation for Stump Puller cam?
Cliff,any info on the spring?
color me gone
Old 06-01-2013, 11:42 AM
Cliff R's Avatar
That application should make at least 11-12" vacuum at idle speed. I'd use the light blue spring that we have in our PP spring kit.....Cliff
Old 06-01-2013, 01:04 PM
67cruiser 67cruiser is offline
I have my Marine Tex on my plugs for 3 yrs. now, showing no signs of coming off?? Maybe your using something differant?? I to check fuel wells with 30 psi of air and soapy water & never seen any marine tex leak as of yet( knock on wood) Great stuff for sure!!
Old 06-01-2013, 02:34 PM
1969GTO's Avatar
Default spring
thank you Cliff
color me gone
Old 06-02-2013, 03:59 PM
1969GTO's Avatar
Default Parts
order has been placed......thanks Cliff
color me gone
