Old 08-13-2013, 06:57 PM
p4msi1's Avatar
p4msi1 p4msi1 is offline
Send a message via AIM to p4msi1
Silver, last friday I put M/T drag radials on it. Also, 522 is the peak torque and it went steadedly down from there, unless you have a download problem, I can read the whole sheet.
Old 08-13-2013, 07:06 PM
p4msi1's Avatar
60Man, What is your engine combo?
Old 08-16-2013, 10:36 AM
Bill Bolin's Avatar
Bill Bolin Bill Bolin is offline
Cajun Man......I hope to see you racing with the Outlaw Pontiacs soon!!!
Old 08-16-2013, 11:03 AM
se428bandit's Avatar
se428bandit se428bandit is offline
Looks like a nicely optioned '69 firebird. Is it a warwick blue car?
Old 08-16-2013, 01:01 PM
Steve Barcak's Avatar
nice numbers, nice car. enjoy!
Hundreds of Pontiacs in Az
Facebook- Pontiac Heaven
Hosting-
Phil 2:11
Old 08-16-2013, 01:11 PM
60man's Avatar
60man 60man is offline
It WAS a Tiger headed 505 IAII......broke a rod last month..
Was strickly a race motor...14.8 CR....large SR cam.....857 lift..
Gaydosh has it now for the 541 build..and have head inserts done..tired of doing head gaskets.
ECM member.
MANDRA
Old 08-16-2013, 01:25 PM
wakesupremo wakesupremo is offline
This thread is way above me as I have been told that a +0.060 overbore is too much. How much are you guys overboring and what is 'special' about the blocks etc that you're using? I am finding this incredibly interesting after the problems I've encountered.
Old 08-16-2013, 02:00 PM
Pitch 400 Pitch 400 is offline
They're using the IAII blocks. Check out All Pontiac.com.
Old 08-16-2013, 03:36 PM
Thanks. I'll do my research.
Old 08-16-2013, 06:03 PM
p4msi1's Avatar
Bill Bolin, I figured I need to step it up before going to the outlaw Pontiac race. Its still has no roll bar in it but in a couple of months I'll solve that and pass tech. Are you racing? Hey does Tony let B-Boy drive the Goat?
Old 08-16-2013, 06:10 PM
p4msi1's Avatar
60Man, are you loosing the head gaskets at 3-5 and 2-4 cylinders? The last time I saw the Dirty Bird heads, Dave install a copper insert in those areas I guess that is what you are doing also. Is the 541 more street oriented?
Old 08-16-2013, 06:13 PM
p4msi1's Avatar
SE 428, Because of the options, that is the reason I have not really done too many racing type modifications, but its getting a rollbar soon and if its really nice to be, I'm also mini-tubbing it.
Old 08-16-2013, 06:16 PM
p4msi1's Avatar
Question
Se428, Light Stellar metallic blue, I think its an old Hyundai color. (See, I'll do anything to increase the performance of my car).
Old 08-16-2013, 07:16 PM
twooldgoats's Avatar
twooldgoats twooldgoats is offline
This caught my eye. It does look like an identical color to my Tempest (an '04 Hyundai Santa Fe color ). It does make it faster, though.
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft)
7.75 @ 178 pass:
https://www.youtube.com/watch?v=Iez3...ature=youtu.be
First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be
Thanks to Paul Carter @ Koerner Racing Engines
Old 08-16-2013, 08:42 PM
p4msi1's Avatar
Jim, I guess the "cat's out the bag" on our performance secret coatings. Pontiac tough with Hyundai stuff.
Steve
Old 08-16-2013, 09:41 PM
60man's Avatar
Yep.....loosing seal between two center cylinders....75-80 passes. doing the same insert I assume.... 541 is going to be another race motor...little more CR, & bigger cam with 4-7 swap. The GP is not a street car..a back half car with tin work..
The old 60 will be my street ride...
FWIW: the 505 made 719 pdft torque..!!
ECM member.
MANDRA
Old 08-17-2013, 10:35 AM
p4msi1's Avatar
719 lbs. torque-----Brutal. What intake and carb?
  #38
Old 08-17-2013, 12:35 PM
60man's Avatar
Using a Gutsram with dual Holley 4150's/850's with race fuel.
Ironic thing is we were trying to lower TQ as I was having trouble hooking up
with 60 Ventura. Go for HP...... will say it moved that 4,100 # sled decent.
ECM member.
MANDRA
  #39
Old 08-18-2013, 11:30 PM
Bill Bolin's Avatar
I should have my car at the next race...Sept 8th at Mason Dixon. And NO, Tony drives his own car.
  #40
Old 08-19-2013, 12:09 PM
60man's Avatar
Cool Bill.....be checking it out..
Not sure 60 will be ready..or I will be ready for a 14 second pass...I hope
C'mon up Cajun man..
ECM member.
MANDRA
