Old 11-08-2013, 09:39 AM
grandville455's Avatar
grandville455 grandville455 is offline
The cheapest route is the E-85, but I don't know if this was a street/strip deal how things hold up? Race only its a no brainer IMO.
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,[email protected]@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected]
M/T 275/60 ET SS Drag Radial
2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's
Old 11-08-2013, 03:48 PM
rocky's Avatar
rocky rocky is offline
Originally Posted by t37owner View Post
I run #62s and converted over the E85 this past year ... spend your money on an E85 carb and save yourself a ton plus have a much more consistent race car. You won't regret it.
If you don't mind me asking what carb you are running?I am running a 1050 holley dominator right now.
Old 11-08-2013, 03:57 PM
rocky's Avatar
I did a google search and found this conversion kit is that the way to go?
Old 11-08-2013, 07:05 PM
Probird's Avatar
Probird Probird is offline
Do you have the right tools to change the boosters?
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0
2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion
and 2015 IHRA Div 5 Mod champion
2024 Chief of the Pontiacs
Old 11-08-2013, 08:26 PM
rocky's Avatar
i am new to this what tools do you need to change the boosters
Old 11-08-2013, 08:39 PM
rocky's Avatar
http://www.e85carbs.com/?gclid=CNvL1...FW_NOgodPCcACg
Old 11-09-2013, 11:07 AM
First depending if u have a old style DOM or new Hp style will depend if u have to sand down the sides of the banjo's to fit in body if old style, second u need to thread the booster pins using a 10/32 tap and pull them out, I built a small slide hammer like the one in the pic, works slick as hell. Then to install the boosters pins u just need a brass drift punch with the same curve as booster pin, put a little loctite on them, think i got mine at Harbour freight, fit perfectly.
Darby
Old 11-09-2013, 07:02 PM
rocky's Avatar
I have the newer style HP carb
Old 11-09-2013, 07:04 PM
Then the banjos should go right in, easy to change out.
Darby
