Just an update to the swap out of the 2 spd to 4 speed stick. I found and purchased a M20 (with shifter assembly) from a 1966 or 67 Camaro Casting #3885010. Ratio: 2.52 / 1.88 / 1.46 / 1.00
I also found some other parts on eBay "Bell Housing, Clutch/Brake pedal assembly, Upper Clutch rod, z-bar, and clutch fork". I'm happy that I could find most of the parts relatively easy, but I'm having problems finding the lower clutch rod that will directly fit a 1966 GTO/LeMans. If anyone has a source for the lower clutch rod or a part number for it I would appreciate it. Now I have to find the hardware, springs, pressure plate and clutch kit.
I found a nice reference page for muncie transmissions and casting numbers which was very helpful.
http://www.5speeds.com/muncie2.htm
Daryl
