Old 01-12-2014, 11:22 AM
GT182's Avatar
GT182 GT182 is offline
Find a way to keep the underside dryer so moisture from the ground won't make it rust any worse than it is already.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 01-12-2014, 02:59 PM
SD421's Avatar
SD421 SD421 is offline
I agree, just start driving it.
Take it from me, my 66 GTO has been parked since 1999 and now Im almost to the point of getting the motor back in and firing her up but dont do what I did which was to park it to redo the whole car.
Dont feel overwhelmed by it. Just work on it in SECTIONS. It will help you from feeling overwhelmed. I would first get a new carpet and go from there.
Keep at it!!
-Don
1966 GTO
1966 421-10.1-1 comp-Race Tec 23cc Pistons
KRE Tri-Power
KRE 65cc Aluminum Heads
XE274 cam by Comp Cams
DUR 230 Int 236 Exh @.050 - 110 LSA
LIFT .491" Int .491" Exh
Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers
1966 Muncie Wide Ratio 4-Speed
1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears
Old 01-15-2014, 04:29 AM
Hitchhiker Hitchhiker is offline
Originally Posted by 65Mark View Post
Looks like a fathom blue car, nice color. I just did a fathom blue 67 and finishing a nightwatch blue 66 now. I can arrange for you to see the 67 if you want some eye candy encouragement. I would at least get it sealed up and water tight if you plan on storing outside.
I think it is Tyrol Blue? but not completely sure.
Originally Posted by Old Blue 66 View Post
After a closer look, does it have gauges in it??
No gauges currently. I have the rough set of rally qauges and a nice idiot light set.
Originally Posted by jd66 View Post
It appears you are missing your VIN tag, might have a parts car here. jd grim 66 gto
No, it's there. You just can't see it because the door isn't open enough.
Thanks for the encouragement guys. It does run and drive. I drive it occasionally. But as you can see, it's not really complete enough to drive a lot. It is a leaker,so that is why I haven't put the interior in. Now that I have it back at my house, I am starting to think about rust repair and having Maaco paint it. Unfortunately it doesn't fit in my garage, so that is a major hurdle. If I can get it dry inside, painted, heater and wipers. I would basically like to drive it on the days I'm not driving this....also no heater or wipers
The Following 3 Users Say Thank You to Hitchhiker For This Useful Post:
Old 02-05-2014, 01:45 PM
Now THAT is my kind of truck. Love that.
Old 02-05-2014, 02:01 PM
Andre's Avatar
Andre Andre is offline
A leaking car in Seattle is like a leaking car in South Florida. If it isn't raining now, it will soon be.
Old 05-05-2014, 10:06 PM
BLUE67gto BLUE67gto is offline
Hey guys, I found my old account.
this is my car,
I've set a goal of striping it, rust repair, and straightening the panels this summer.
I started this week with removing the rear window. Someone had used hardware store caulking to "seal" it at one time. It's gonna need a fair amount of rust repair in that area. Before I dig in, has anyone posted a good walk thru yet? I just want to familiarize myself with the area first, before I start cutting.
thanks
Matt
67 gto
400/4sp
Old 05-06-2014, 05:40 AM
Old Goat 67's Avatar
See my post # 14 in this thread.
http://www.forums.maxperformanceinc....ht=rear+window
