Old 01-13-2014, 10:03 PM
deputydog's Avatar
deputydog deputydog is offline
I run the Kauffman hi ports on my 461,minimal porting (348 cfm), unported victor. 1050 dom, 13to1 comp, small solid roller. 67 tempest ,3850lbs all steel and full interior, 9" slick and run 1040s through exhaust....I'm very pleased with the hiports
The Following User Says Thank You to deputydog For This Useful Post:
Old 01-13-2014, 10:20 PM
ponjohn's Avatar
ponjohn ponjohn is offline
That is impressive.
What are the cam specs?
And what mph?
The Following User Says Thank You to ponjohn For This Useful Post:
Old 01-13-2014, 10:24 PM
demonic68's Avatar
demonic68 demonic68 is offline
Originally Posted by Half-Inch Stud View Post
technical reading & writing skills, a curse & a blessing. HIS
Back to topic
It's all good we are all car guys and if I can't take a little crap I probably should go buy a Honda lol joking
yes back to topic
Old 01-13-2014, 10:28 PM
demonic68's Avatar
How does it do on like cruise nights if you take your car out?
deputydog's Avatar
690 lift, [email protected] all isky valve train..still more in it only went 1.50 60 ft...I take it cruise nights more than track...mechanical fan and water pump never goes above 180-190...I drive it everywhere even Home Depot...lol. The hi ports have nice chamber runs best at 30-32 total timing
Old 01-13-2014, 10:54 PM
demonic68's Avatar
On 13to1 wow I am thinking I didn't aim high enough lol. What kind of fuel are you running?
Old 01-13-2014, 11:22 PM
Dragncar Dragncar is offline
550 HP????? You do not need much of a head for that, or 12-1 CR.
I am getting at least 550hp out of iron HOs on CA pump gas.
Bone stock E heads or High Ports will get that with the right cam easy.
The Following User Says Thank You to Dragncar For This Useful Post:
Old 01-13-2014, 11:25 PM
deputydog's Avatar
At track I only run vp110...on street I run cheaper turbo blue 110...I plan on switching to E85 this summer, cheaper, runs cooler and pick up tenth or so
Old 01-14-2014, 12:00 AM
demonic68's Avatar
Yeah I am aiming for 550 as a base line that way if it didn't make that I wouldn't get so damn depressed over not making lets say 560 I know the block limits are 800 hp if i am lucky and have a block that isn't weak at the mains.
Old 01-14-2014, 12:01 AM
demonic68's Avatar
E85 is my plan too. I just need to pick up a good E85 carb.
Old 01-14-2014, 12:20 AM
David Holmberg's Avatar
You don't need that much compression, or cam.
My combo was with 87cc heads, and ran on pump gas. My cam was a 254/262 - .600 lift.
This was built back around 2000, much better cam choices today. Now I'd use a hyd roller that's smaller than my old cam, and it would go quicker.
For 600hp or less, pump gas is all you need.
Old 01-14-2014, 12:47 AM
demonic68's Avatar
Well don't get me wrong I would love to have 700 HP on tap try and show these Turbo Chevy boys that Pontiac's are a force to be reckoned with. But I know my stock block will be the weakest link in all of my engines combination. This is why I set my self a wheel horsepower rating of 550 hp NA then add the 250 shot of nitrous on top of 550 which if I have read everything right leaves the engine in a safe zone and obviously if the engine makes more power in NA form lower the dose of nitrous.
Old 11-12-2014, 03:46 PM
torqjunki's Avatar
torqjunki torqjunki is offline
Check out the first post. He is looking for 550 WHP.
1971 Base Firebird..505ci IA 2A Round port E-heads by Butler 348 cfm.. Comp street SR 266/[email protected] Victor intake/Quick Fuel Q950. 1 7/8" Dougs headers..3" mandrel bent exhaust with Hooker Max Flow mufflers, T-350 well built with 10" 4000 stall nitrous Continental converter..3.73 posi . Caltracs and 10" slicks. Belt driven water pump, alternator, Pwr steering and brakes,Flex fan. 11:1compression, straight 93 octane pump fuel. 10.35 @ 129.88 with 1.45 60ft N/A at 3700lbs race weight.
Old 11-12-2014, 03:49 PM
torqjunki's Avatar
Wow...I brought that post back! Maybe I should check the date!!
Old 11-12-2014, 04:19 PM
The moment when you see the date...
Old 11-12-2014, 04:41 PM
Tom Vaught's Avatar
Boost Engineer
Originally Posted by J.C.you View Post
3. Out of the box HPs will easily make 700hp. If you want to talk flow numbers, I have flowed a stock HP on Meaux's sf 600 bench (TV will vouch for the accuracy of his bench) with a 2.075" intake and it went 317 cfm @ .700 lift. on a 4.125 bore.
ANY number you get on Larry Meaux's SF 600 bench you can take to the bank.
Larry, myself, and a bunch of other guys with Flow Benches did a Nationwide Calibration
check using a $3,000,000 Flow Bench as the standard and Larry's bench was very close in accuracy to that bench.
Tom V.
I am also a fan of the HP casting as I feel it is an upgrade for a bunch of people over a basic "Summit" E-Head without a lot of work. I would take the flow numbers from the supplier with a grain of salt as they do not match very well in given spots on the air flow bench curves compared to a bench like Meaux bench. The difference is the design of the supplier's bench and the way that it gets the data vs the SF Benches.
Tony B's bench checked out really close too when calibration plates were used to check his bench
Old 11-12-2014, 07:16 PM
wolfs63's Avatar
wolfs63 wolfs63 is offline
I'm using Butler's 320 cfm E heads on a 535, 9.50 140 @ 3200 lbs. 63 lemans. Either head will work well.
