1982-92 TA & FB TECH 1993-2002 TA & FB Tech is now part of the new Late Model Section of the PY Forums. Click this link to check it out.
Old 03-26-2014, 10:40 AM
mrrat1 mrrat1 is offline
nice thanks!
Old 03-28-2014, 12:16 AM
Pontiac originally planned on putting the 301 in the 84 bird so the hole for the Pontiac mounts were put in the front part of the front crossmember. Putting the 400 in the 84 should be real easy as I saw one done back in 86 in an 85 T/A. It was at a show in Shaumburb IL. at a show at a dealership & a guy had a $%% SD engine in it & everything was hooked up & working. Even the A/C worked with no problems & he said he did it with all GM parts from over the counter. Your is looking good, keep it up you'll have a great car when it's done.
Old 03-28-2014, 09:28 AM
Thanks Rex, working on getting a good rebuild kit for the 700R. All are listed as 87 & up.
I have a 84' unit so are they the same as far as rebuild kits go?
Old 03-28-2014, 11:14 PM
I'm not really a tranny guy but I would stop at one of your local trans repair shops & tell them what trans you have & they should be able to sell you a kit that is right for you. Also they will be able to tell you the best parts for the trans to stay together when you put it behind your Pontiac engine , because the Pontiac engine will be a lot more powerful then the chevy engine that it was with before.
Old 03-31-2014, 11:12 PM
TTOP350 TTOP350 is offline
Originally Posted by mrrat1 View Post
I want to utilize the 1LE dual cat set-up. So the head pipes will have to be modified.
Just a heads up, 1LE is the RPO code for the dual piston PBR caliper front brakes w 12" rotor.
N10 is the RPO code for the dual cat exaust and was offered from 89 to 92.. It was also on more non-1LE cars than it was 1LE cars.
Great project, I'll do one some day!!!
http://www.fquick.com/garages/viewga...ewimg&id=74990
"You people have stood in my way long enough. I'm going to clown college."
-Homer Simpson
Old 04-01-2014, 10:11 PM
tininjun68's Avatar
tininjun68 tininjun68 is offline
Great and fast progress! My son is considering a similar swap into his '83 T/A. Anyone do one using a stick? I assume the factory 5 spd won't live too long behind either a 400/455 and my son wants to keep the car stick.
You know me, "Safety Forst"
68 GTO-Verdoro/Black/Black, what else was available in ‘68? Has to be longest resto in history.
69 GTO Vert-Liberty/Blue/White Top, 4spd, match #’s
68 Mustang FB-Green/Black (Bullitt)
Old 04-02-2014, 10:00 AM
Tininjun sent you a PM
Heres a link to my Phototbucket
http://s1277.photobucket.com/user/Mrrat1SSJ/library/
Old 04-02-2014, 03:02 PM
TT thanks for the correction!
The front suspension kit is installed, and shes a roller now. It's all gonna get broken down again after its up & running.
I will have to paint control arms & get some things powder coated.
The new struts & big brakes will go in on the final assembly.
The engine in the video & car is just a beater to get mounts and such lined up. I will have a built 462 that will go in with the HD 30 spline 700R. Waiting on Cliffs tranny book to order the recommended hard parts & rebuild kit.
Old 04-03-2014, 10:54 AM
The T/A starts on page 18.
Old 04-11-2014, 01:56 PM
Cliffs book arrived & now on the trans hunt!
New Steering box & shaft installed.
Power steering pump & alt installed, waiting on metric conversion inserts to connect lines.
Remote oil set up will be used so looking for a kit.
A/C compressor next.
I'll post up pics next week in my photobucket.
Thanks Dave
Old 04-13-2014, 11:09 PM
dragincar209 dragincar209 is offline
Default New to this forum
Hello I'm new to this forum. I also have an 84 Firebird, I race it at our local drag strip. This is cool because until today the only info and/or forums I have found on this subject was over 9 years old and out of date. The links and web sites connected to it were gone.
Right now in the car I have a std bore 350 chevy with a TH 400 and a Ford 9 inch rear end hung in there with Competition Engineering ladder bars and a CE sub frame kit. I'm only doing low 13 to high 12 sec 1/4 mile times at this point but I'm having fun with it.
I have acquired a 71 Pont 400 that I'm planning on building with a stroker kit to make either a 440 or 462 CID I haven't decided which one yet. At some point also I'll be installing at CE 8 point roll cage and other mods to stiffen up the car, as I have found these are weak unibodies.
I already have learned a couple things from your posts (what frame motor mounts to use and about the extra holes in the crossmember) I'll be looking forward to future ones. BTW what do you plan on do doing to stiffen up the car? It's clear you are going to drive this on the street and that engine will have a lot of torque and from the pics I saw you had a T-top so body strength likely will be an issue.
P.S. Here is a pic of my ride at the strip.
Old 04-14-2014, 09:04 AM
Hey Dragin , thanks for the post!!
I found the same when I looked for info on the swap!
I will be getting the Spohn frame connecters, tranny crossmember, and torque arm.
Your car is set up exactly as the Schools race car, minus the mini tubs. It's running a 383 w/144 super charger, T-350 4.70 9" rear. Its running 11.0's.
Will have cruise control & A/C also. Gonna look stock outside & inside.
Thanks Dave
Old 04-24-2014, 03:10 PM
Brake Booster & Master installed.
Engine harness laid out and partially connected.
Power Steering line inserts arrived and put in.
Waiting for remote oil filter parts to arrive.
Heater hoses are hooked up, installing radiator & A/C condenser tomorrow.
Old 04-29-2014, 04:27 PM
Radiator not in yet & not too much going on due to Easter & testing.
New Battery cables have been made.
Old 05-23-2014, 01:29 AM
howestempest howestempest is offline
I put a 4L80e on my Pontiac 400 and got it in my 88 Firebird
ID:	364509   Click image for larger version
Old 05-26-2014, 10:25 AM
Not much to update! Lots of study sessions & practice tests going on right now.
Watching the mail for trans cooler lines and fittings & lines for remote oil filter.
Hey Howe you have it up and running..........I hope to upgrade the trans in the future.
Any hurdles to be aware of?
What controls the trans?
Old 06-03-2014, 04:11 PM
Had to order some fittings for remote oil set up. It should be completed this week.
Most of the wiring has been sorted. Cooling system in place.
Front suspension back together with new bushings.
New brake lines installed.
Need to find bracket for TV cable & go pedal, get a choke in place.
Only 2 weeks left of school. Should be up & running very soon.
  #38
Old 06-10-2014, 03:13 PM
Alt & PS pulleys are a little cock eyed so that has to be squared up.
Just have the throttle bracket to install, and turn the key!
Too busy at work today but will go up tomorrow to check status!
  #39
Old 06-30-2014, 01:27 PM
Schools out and the T/A runs from the key, stops & shifts.
A/C & gauges are next on the list to have up & running. Won't be much getting done over the summer.
  #40
Old 12-08-2014, 10:48 PM
Anything to update status? nice project.
