Old 06-10-2014, 02:04 AM
Blued and Painted's Avatar
Blued and Painted Blued and Painted is offline
The skinny rims will pull the edge of the tread away from the ground. Get down there with a business card and see how far you can push it under the edge of the tread.
I'm guessing the 275 are about 10.5 inches wide. IMO, 9" would be the minimum width to take advantage of the available contact patch of the wider tire.
But yes, you can mount them on 7's.
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk
Old 06-10-2014, 06:41 AM
goatless's Avatar
goatless goatless is offline
Did you look at any of the pictures posted above? The tread is in FULL contact with the ground as you would expect it to be.
1966 GTO
Old 06-10-2014, 07:48 AM
The Boss's Avatar
The Boss The Boss is offline
295/50/15 B.F. Goodrich Radial TA's, not sure of the rim width.
Name:	IMG_3472 (1280x960).jpg
And go racin' in the street.
Old 06-10-2014, 07:55 AM
HJones1313's Avatar
HJones1313 HJones1313 is offline
Send a message via Yahoo to HJones1313
I ran 275/60-15's on 15 X 7 rims on my El Camino canyon burner for years without any problem, and I've got Hoosier GT's in the same size on my '70 GTO, again without any problems.
Name:	Hoosier rear tires 06.jpg
"GTO......Gas, Tires and Overdraft"!
'70 GTO convertible, 434, 4-speed
Old 06-10-2014, 02:08 PM
^^^ Note more ware is in the middle of the tire vs the outside.
Not saying it wont work or doesn't look good.
Just saying the extra tread width wont be utilized.
you can drop the tire pressure but it still wont have even contact pressure across the tread width.
Old 06-10-2014, 05:30 PM
The Champ's Avatar
I think the point that many are missing here is that just because a 275/60 can physically be mounted to a 7" wide rim doesn't mean you should or that it's safe to do it.
Tire manufacturers have engineers that believe that at least a 7.5 or an 8" wide rim is what should be used for this tire size.
I'm sure that there are good reasons for their belief.
Old 06-10-2014, 06:05 PM
goatless's Avatar
I knew it was only a matter of time before the Champ was here...
1966 GTO
Old 06-10-2014, 06:07 PM
goatless's Avatar
The "ware" pattern looks pretty even to me.
1966 GTO
Old 06-10-2014, 06:22 PM
65gto69's Avatar
65gto69 65gto69 is offline
My wear pattern is even across the tires on both sides and I have been using this setup for over 7 years now and I bought the tires and rims used which had several street miles on them and some track time before I got them.
Just saying
mark
1965 GTO: 467 (Built By Dan Willever), 400 Block, Eagle 4.25 Stroke, Eagle 6.8 Rods, BRC Pistons, Custom Grind Hydraulic Roller Cam, Edelbrock 72cc Heads Ported, HS Rockers, Doug's Headers, Edelbrock Victor 4150, QTF 850 Carb, AutoGear M22 4 Speed, SPEC Clutch and Pressure Plate, 12 Bolt 3:73 Posi.
Old 06-10-2014, 07:16 PM
Steve C. Steve C. is online now
Example from old Firestone sales material, Firehawk INDY 500 tires
Size P275/60-R15
Approved rim width 7.5 - 9.5 inches
Measuring rim width 8.0 inches
SW 11.0 inches on 8" rim
TW 9.0 inches on 8" rim
Old information here:
Old 06-10-2014, 08:22 PM
NotaT/A NotaT/A is offline
It seems that GM is ok with a 275/60-15 on a 7" wheel. They have done it on several truck applications.
See attached tire placard
Name:	Tire Placard_ c.jpg
Old 06-10-2014, 08:31 PM
How 'bout that for the doubters.
Old 06-11-2014, 03:10 AM
Can someone get a measurement of the tread with of the 275 please.
Old 06-11-2014, 07:09 AM
The Champ's Avatar
I held myself back for quite awhile...
Old 06-11-2014, 07:11 AM
The Champ's Avatar
Just saying
mark
I would get those tires off my car now, even if they were new when you bought them. I won't run any tire more than 7 years old.
Old tires = a much greater risk of a catastrophic tire failure.
Old 06-11-2014, 12:21 PM
"Can someone get a measurement of the tread with of the 275 please"
Size 275/60-15 used to more available and the actual tread width would vary slightly from the different companies.
Today BF Goodrich, Cooper and Hankook all suggest a 8.9" tread width measured on a 8" rim for their 275/60-15 tires. As mentioned previously Firestone when they carried that size suggested 9.0" tread width on a 8" rim.
Actual section width on the various tires will vary as well.
Old 06-11-2014, 01:01 PM
This calculator said 10.8" wide. 28" tall. http://www.calcunation.com/calculato.../tire-size.php
Found this on the net. It must be right.
Note the * at the bottom of the page. Supports my point.
http://www.team3wheels.com/tech_specs_tire_chart.html
  #38
Old 06-11-2014, 01:08 PM
goatless's Avatar
Yes, section width will vary based on rim width. No one is arguing otherwise. Doesn't mean the tread isn't making full contact.
1966 GTO
  #39
Old 06-11-2014, 01:17 PM
Interesting that the engineers at General Motors thought that a 7" wide rim would work fine.
But what do they know ?
  #40
Old 06-11-2014, 01:44 PM
Transporter Transporter is offline
Although I think it is really up to the individual and on the street I really don't see any issue with the 275 on a 7" rim, the old standby (at least as far as road racing and circle track goes) used to be at least an inch of rim width for each inch of tread width.
With that said the 275 has a "tread" width of 8.90 on a BFG, so it would be best on a 9" rim.
As I said, I have my 275's on a 10" rim and in order to match the "look' of the tire I also mounted 215/65/15 on 8" rims on the front, overkill? Maybe, but I like the look, to each his own. JMHO.
