Old 07-05-2014, 11:19 PM
70RAlll 70RAlll is offline
If you will re read my post, you will see I said FS and FP radiators are assigned the '086 shroud.TA only came with the FP or FS radiator, hence '086 is a TA shroud. Your espirit had HD cooling, which I listed in one of my initial posts that the '086 would be supplied if HD radiator was an option. Again, the other shroud is for the 350 or base non RA 400 engines w/o HD cooling. I am pretty sure the tanks on the FP,FS radiators are larger than tanks on the standard 3 row radiators. Eitherway doesn't matter.. I think we have hashed this out to its end.. the pdf file I attached shows all anyone will need to know what is correct.
Old 07-14-2014, 02:29 AM
roundportponchos's Avatar
Default rad
Should my 71 stick, TA, non ac, 342 rear, have a 3 or 4 core? I need a rad, if anyone can help, and a 8436 starter. I have a 086 shroud. Is that correct?
Old 07-15-2014, 10:44 AM
3tas4me's Avatar
3tas4me 3tas4me is offline
I believe 3 row would be correct unless your car was ordered with heavy duty cooling.
1970 Trans Am
1971 Trans Am
1974 Trans Am
1978 Y88 Trans Am W72/auto
1979 10th Anniversary Trans Am
1984 Trans Am
1996 Trans Am WS6
1999 30th Anniversary Trans Am
2001 10th anniversary Firehawk #104
Old 07-15-2014, 01:43 PM
TA455HO's Avatar
TA455HO TA455HO is offline
Agree. My 71 non-AC stick 3.42 car still has its original 3 core.
What date coded 8436 were you looking for?
Old 07-15-2014, 05:45 PM
68bird400HO's Avatar
Nice.. an original car that can maybe offer up some info....
Does your radiator still have the tag?
Can you tell what the tank codes are?
If your shroud is original too, which one is it, the 114 or the 086?
Old 07-15-2014, 09:08 PM
TA455HO's Avatar
Not meaning to mess with Greg's wanted thread, maybe we should move this over to the regular forum?
I'll start a new thread there.
Old 07-17-2014, 12:21 AM
Default rad
I need a rad for 71 stick TA, non a/c,, if anyone can help
many thanks
Old 07-17-2014, 10:45 AM
skunkwerks's Avatar
skunkwerks skunkwerks is offline
I agree that the passenger side tank is the same thick version regardless of 3-core versus 4-core. But the shrouds differ by the lip that goes along the driver's side tank. On all of the original 3-core radiators I have seen, that driver's side tank is thinner than on the 4-core radiators. So, a 3-core radiator actually has two different sized tanks.
Agree with what you say. I have 5 original Harrison radiators and they all came from 70-73 Trans ams with different cooling options. Tanks are key.
White/Blue 71 455 HO T/A Auto
Blue/Blue 71 455 HO T/A 4 Sp
White/Sandalwood 71 455 HO T/A 4 Sp
White/Black 70 RAIII T/A M21/373 (stripper)
Carousel Red/Black 69 GTO Judge 4 Sp
2002 Firehawk Red/Black 6Sp
Old 08-03-2014, 12:00 PM
165th's Avatar
165th 165th is offline
TTT....
I'm still looking for a pristine/NOS radiator shroud
